Wheel Horse Newbie -- with a few questions
By
WheelE, in Wheel Horse Tractors
Similar Content
By Rick3478
- SOLD - Moderator may remove at will
0736TL04 tiller and fitments needed to mount on many long frame, C series, 300/400/500 series tractors.
Notable details:
Gearbox and tines have low hours. Tarp had blown off mid-mount idlers and got rusted up, probably need penetrating oil and new idlers.
Axle mount is rusty/restorable/useable. Lift cable has nylon worn through on one side (they tend to do that). One rear jackshaft bushing
has couple ears broke off, and jackshaft e-clips are lost (edit: found those). Belt is original.
Pick up in my back yard near Elida, Ohio. Bring help to load, or ramps or something.
I think it may be worth $100.
- or -
Would consider trade for a used car or truck hood that I can use for a sled to drag firewood and equipment around on, something kinda
rounded without points or ridges to catch. Have been using an S-10 hood for years, and it's wearing through becoming less useable.
What 'cha got?
By rustyedge1
Belt in photo is K Force brand A 102742 which is what my local parts place is pushing at 30 bucks plus.
This one was bought two seasons ago counting this mowing season and it’s not going to make it looks like..
Any info on better made belts appreciated..
By River Rat
I am looking for the Wheel Horse part number for the Mule Drive belt on my 1984 C145A 11-14KE01. I believe it is 102742. The old one is stretched quite a bit and not sure the outside length. possibly 1/2 by 103 in? 48 inch mower.
Any help is appreciated!
By Epayne85
Hello all, I have a what I believe is a 36” tiller.
i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
By morePEdal
1989 Wheel Horse 520H
Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
I am in Germantown, Wisconsin.
Comes with:
-42” Deck
-Two- Single Stage Snowblowers, one is attached.
-Tiller
-Snow Plow
-Hard Top, Soft Sided Cab, in good shape
-Hubcaps
-Cast Iron Weights
-Chains
-New Battery
-New Snowblower Belt
Price: $1100
Cross Posted.
