suburbanrider
Ignition switch
suburbanrider
Im looking for an ignition swich to start my lawn ranger 12631.  One of the prongs broke off whre the wires connect to the switch.  I cant find the part # or where to purchase.  I currently touch 2 wires to the battery to start
I have the original key and switch.  It would be nice to have an original switch, but a new replacement will do
Thanks!
Jerry77
:text-welcomeconfetti:  Before the day is out you will have all the info you need from the members here...:)
gwest_ca
Ignition switch 7572 replaced by 101482 for electric start and still available from Toro
Garry
  • Like 3
suburbanrider
ok!  I will check it out!  Thanks
DougC
Hello and   :text-welcomeconfetti:to the forum!!! :)
  • Similar Content
    • suburbanrider
      By suburbanrider
      Hi fellas
      I have a WH 1-2631 with a blown engine and im looking for a replacement
      Motor is a tec H60-751176
      I cant find any on ebay.  Where do you suggest I can look?
      I live in the Cleveland, OH area
      Thanks
    • suburbanrider
      By suburbanrider
      Question...
      I just purchased a vintage Wheel Horse Lawn Ranger and I was mowing the yard.  Towards the end, motor started smoking a bit underneath the engine and then shut off.  Now it wont start.  I started trouble shooting and I found out there was barely any oil in it.  Drained the oil and maybe 1 cup of oil came out.  I put new oil in and after about 2 pints, it started to leak at the connection from the drain valve to the motor (towards the rider).  I see that the connection is loose, so now I have to take the battery out and try to tighten the connection between the drain elbow and the motor.
      Also, after putting the oil in it, I tried to start and the motor spins, but thats all.  I dont hear any engine compression sounds.  I just hear the sound of the motor rotation (kinda hard to explain, but i hope you get the idea).  It seems like there is possibly no compression.  Im not sure though.  Ive never dealt with a compression issue.
      Im guessing the motor isnt seized since it turns with the electric start and the pull cord.
      Spark plug replaced and sparks and I removed the fuel line to the carb and gas was flowing so im guessing the problem isnt either of these issues
      Is the motor destroyed after automatically shutting off with no oil?
      What can I do?
      thanks
