Red520
1995 520H
Red520
I just purchased my first wheel horse tractor. It is a 1995 520H serial #5901574 and I have a few questions to ask. When I received the tractor the idler pulley on the main drive belt was shot so I replaced it. I notice that the drive belt is still doing a lot of jumping and may be stretched. The parts diagram shows the belt but the diagram doesn't seem to be the same as my model. It lists the drive belt as 5/8" x 83". Can anyone tell me if this is correct?  Also the hydro transmission seems to be slightly engaged when in neutral and it will move forward when parked. If I put the brake on it sounds like the transmission is trying to move. Any adjustment for this? I am using this to mow about 3 acres of grass that has a lot of obstacles and I am wonder if the hydro tranny will take a lot of forward and reverse motion? I did tighten the bolt a little on the tranny shift linkage to stop the shift lever from dropping down when it was in motion.
rmaynard
The correct part number for your belt is 114895. It is 5/8 x 83" (cloth covered). The adjustment for the "creep" is found in your owners manual, and if you don't have one, it can be downloaded from our manuals section.
:WRS:  Glad to have you.
  • Like 4
bmsgaffer
:text-yeahthat: And yes your 520H will handle lots of forward and reverse around obstacles with no problems.
I would recommend a "Matt's Hydro Foot Pedal Kit" which eliminated the hand control and puts the drive control to your right foot more like a modern hydrostat. Then adjust your creeping and those 520s are quite maneuverable.
  • Like 6
gwest_ca
Garry
  • Like 5
T-Mo
:WRS:
You have a good machine there.  And we like pictures.:wwp:
  • Like 5
rmaynard
What bmsgaffer said. I had the hand control on my 416-H and absolutely hated it. But not having a lot of money to spend, I was reluctant to buy Matt's foot pedal kit. Once I pulled the trigger, I wondered why Wheel Horse never built the hydro's that way. I will NEVER go back to a hand operated hydro. Once you find the neutral stop position, you can loosen up the friction nut, lube the whole assembly for smoother action, and it works like a dream. My Eaton 1100 has 1600 hard use hours on it and it's still going strong.
  • Like 8
JERSEYHAWG /  Glenn
Yes, as stated. Matts pedal kit. You will not regret it.
Glenn
Red520
Do the gauges on these go south quite a bit? I have 3 that are not working. Could they just need the terminals cleaned? The throttle also drops off shortly after pushing it up and I was told that I could take it out and crimp the rivet to tighten it up. Has anyone tried that? I also want to thank all of you for the info you have already provided I really appreciate it.
WHX??
You can try the rivet thing but the nub  that holds it in place at full throttle is probably worn off so a replacement is in order. They are on ebay & reasonable.... 115392 is the P/N. Which three are not working?...there are some guys here real knowledgeable about 520's that's for sure!
:WRS:
lynnmor
I put a small screw with a locknut thru the rivet to restore the friction.
gwest_ca
A good diagram for the gauges
Garry
DougC
Hello and   :text-welcomeconfetti:.   Enjoy the forum and your new :wh:  520H.   :handgestures-thumbupright:
SylvanLakeWH
KC9KAS
@Red520 :WRS: and we want photos!
Red520
The gauges that do not work on my 520H are the alternator, fuel and hours. I haven't done anything with them yet but I hope to get some time soon to check them out. I will send some photos later today. Again I appreciate all the help from everyone. It makes it so much easier to do something when you have insight before hand.
608KEB
I put a small nut/ bolt through the rivet on the throttle if can find a bolt with a Allen screw fitting on the end, that would work better. I'll try to post a picture in the next day or two.
cleat
Sounds like you need to clean up the connections.
The Hour  meter may be toast, most of mine were.
If the tach works that is the most expensive one to replace.
WVHillbilly520H
If the voltage regulator is bad the hour won't work, and as for the voltage gauge a cheap aftermarket one from Advance Auto($17),AutoZone,Napa ect will fit/work I did one of my 520s back in the spring, just had to trim the plastic dash opening to fit the gauge bezel,Jeff.
bmsgaffer
Check your fuses and your wiring first. Theres a good chance something is just blow or wired funky.
Red520
When you say a cloth covered belt is that something special?
Red520
Hello Again,
I replaced my drive belt and got the lights and all of my gauges working. I tried to adjust the drift in the hydro tranny by turning the cam and I was able to get it to neutral but shortly after it started to drift again. I removed the bolt from the cam adjuster because it did not feel right. The cam has flat spots worn on it and needs replaced. Would it be a good idea to also replace the shift plate that it fits into. Where would be the best place to order the parts?
Red520
Thanks for your help Cleat it was just a blown fuse. My tractor has 2 fuses in it a 20 amp and a 30 amp. I saw in the manual that it should have 3 fuses. Is that correct?
bmsgaffer
I would order the cam plate along with the follower, as the cam plate usually has worn pretty loose once the follower has flat spots. I like RCPW.com as they are often the cheapest, but there are several places you can go.
I do know that it is supposed to have three fuses, 30, 20, and a 15 maybe? I forget what they are all for so I will let someone else follow up with that.
TDF5G
:WRS:
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
