Gasser 24 #1 Posted September 18, 2016 Hey everyone I just picked up a Wheelhorse 702 tractor..got it running today and had the side belt cover off and looks like it may be missing a pulley does anybody have a picture they could post of what it looks like under the cover I will try to post some pictures of what I have there now..Thanks Here's a picture of what I have 4 Share this post Link to post Share on other sites
Racinbob 12,244 #2 Posted September 18, 2016 No, you're not missing a pulley. It looks like you have an input shaft seal leaking. I would replace all the seals and service the transmission. You don't need to open the transmission to replace the seals. Make sure you have the belt guard on when you drive it. You need it in order for the belt to stop when you clutch it. 7 Share this post Link to post Share on other sites
AMC RULES 37,235 #3 Posted September 18, 2016 Nice score there Gasser. Share this post Link to post Share on other sites
Gasser 24 #4 Posted September 18, 2016 Thanks guys..that's good to hear! the belt seemed really loose when I engaged the clutch but I guess that's what the cover is for I didn't know if there was suppose to be another tesioner pulley or something that was supposed to be there.. I'm going to change that seal where would you recommend getting the seal and what weight gear oil should I use?thanks 1 Share this post Link to post Share on other sites
Racinbob 12,244 #5 Posted September 18, 2016 Here's a link to a thread that will give you everything. You have a 5025 transmission. 3 Share this post Link to post Share on other sites
wedge 80 #6 Posted September 18, 2016 My Commando 6 is the exact same. Looks like your belt is stretched some also. 1 Share this post Link to post Share on other sites
stevasaurus 23,456 #7 Posted September 18, 2016 Use 90wt oil...approx 2 quarts. 3 Share this post Link to post Share on other sites
Gasser 24 #8 Posted September 18, 2016 Thank you everyone for the info it's a big help..does anyone know the belt number or size? Share this post Link to post Share on other sites
953 nut 62,274 #9 Posted September 18, 2016 Your drive belt is 9691 (replaces 1576) and is a 4L-700 or you could use an A-68. Here is a copy of your manual. Share this post Link to post Share on other sites
Gasser 24 #10 Posted September 19, 2016 Thank you! Is the right side pedal used for attachments? Share this post Link to post Share on other sites
AMC RULES 37,235 #11 Posted September 19, 2016 Yes. Share this post Link to post Share on other sites
Lane Ranger 11,633 #12 Posted September 19, 2016 Gasser: Does your belt guard have the tab on it to catch the belt when tension is released by clutching? Very important. Sometimes you need an extra wire belt guide on the motor especially with a loose older belt. Share this post Link to post Share on other sites
Gasser 24 #13 Posted September 19, 2016 I'm going to check that out when I get home Could you guys tell me what hitches would fit this model I would like to pick up a factory style hitch for it 1 Share this post Link to post Share on other sites
Gasser 24 #14 Posted September 21, 2016 Hey would any wheelhorse hitch bolt up to the 702 or does it have to be from the same model? Share this post Link to post Share on other sites
stevasaurus 23,456 #15 Posted September 21, 2016 A slot hitch is what came with it, and any one would fit. When you say bolt up, do you have something specific in mind? We have a vendor that makes hitches that have a 2" receiver that would mount on the 702 also. Share this post Link to post Share on other sites
Gasser 24 #16 Posted September 21, 2016 That's cool I need to look into that..I meant the standard type like to pull a cart Share this post Link to post Share on other sites
Gasser 24 #17 Posted September 23, 2016 Sorry @Lane Ranger I just got a chance to look at the belt cover today..here's a picture of it..I think it's missing a mounting tap near the engine 1 Share this post Link to post Share on other sites
Lane Ranger 11,633 #18 Posted September 23, 2016 Yes but you can weld one onit! Share this post Link to post Share on other sites
sorekiwi 761 #19 Posted September 23, 2016 Check out your clutch spring on the other side of the transmission. It puts the tension on the idler. 1 Share this post Link to post Share on other sites
Gasser 24 #20 Posted September 23, 2016 OK will do thank you.... What weight oil would you guys recommend running in the Kohler engine? Share this post Link to post Share on other sites
sorekiwi 761 #21 Posted September 25, 2016 I run Rotella 30wt in summer. Share this post Link to post Share on other sites
Gasser 24 #22 Posted October 13, 2016 what wt oil would be good to run now through the winter? It has a k181 Share this post Link to post Share on other sites
wallfish 18,630 #23 Posted October 13, 2016 Kohler recommends 10w 30 for winter temps Share this post Link to post Share on other sites
Gasser 24 #24 Posted October 14, 2016 Great thank you Share this post Link to post Share on other sites
Gasser 24 #25 Posted December 1, 2016 Hey..can anyone tell me if the make any replacement steering parts..my steering on my 702 is very sloppy and and doesn't turn all the way to one direction..it will if you grab the tire with your hand..it looks like a lot of the play is in the tie rods Share this post Link to post Share on other sites
