Similar Content
By KC9KAS
Need assistance! 1977 Wheel Horse C-120 hydro. I sold it to a young fellow last fall. His dad said he put a new battery in it but it still failed to turn over to start. I checked the only safety switch (with an ohm meter) and it is working correctly. I checked all the wires (ohm meter) and they tested ok. I did come to the conclusion the 20 amp AMP gauge was bad. I installed an old one that I had and it turned over and started right up. I already had the voltage regulator wires disconnected and read 36 VAC from the stator. When I attached the wires to the (fairly new) voltage regulator it would immediately cause the engine to sputter and die. The voltage regulator is grounded directly to the negative post on the battery. Once the wires were removed from the voltage regulator it would fire right back up! I am at my wits end trying to figure this one out! Would a bad voltage regulator cause the engine to quit running? I may have to remove a voltage regulator from another known good machine and try it. Anyone have any suggestions? -
By Joe Warren
A guy I know runs all his 4 cycle power equipment engines on 2 cycle fuel. He claimed it reduced engine wear. Aside from the added cost of the 2 cycle oil, are there other downsides. Just curious what you all think.
Joe
And now for the rest of the story: I spoke to the guy again. He was a mechanic at a place where they operate a lot of outdoor power equipment; with both 2 and 4 cycle engines. To prevent employees from putting straight gas into their 2 cycle machines, all their fuel got 2 cycle oil mix with it. For them, it was more economical to spend money on oil, than on blown engines and downtime.
Thank for all the great posts. I found some to be very entertaining.
By JasonMc
Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
Jason
By JoeM
The Ethanol Monster strikes again!
Got out the pressure washer and went to start it, "no dice"
Opened the carb and found those typical ethanol pearls, as I call them.
I used an additive in my fuel last year, Ethanol Shield, did not seem to work very well.
Not wanting to drive 30 miles for fuel, and still skeptical about if it is true ethanol free.
Switched over to Lucas additive now.
Will see.
FYI
Joe
By WHX??
Sadly Dan @Achto informed me the the other day of a 857 and a C-120 that was deposited at his local county dump. Dump rules are such that once it hits the ground it stays due to junkyard dogs going to fisticuffs over scrap steel. Understandable Despite some hastily made plans of bribery, chicanery and/or hook or crook to rescue them we failed miserably. We may get drummed out of the Mafia for that one.
I'll let Dan fill you in on the details if he has the stomach. I would like to believe that that our beloved ones would be smelted down to produce more tractors but then I wake up from that dream. Sorry no bone yard pics not that we would want to see them.
Dan asked me if he had a problem over grieving over these lost gems. You decide... So in memoriam I feel it is quite nescessary to post pics of our lost loved ones. Since I don't have a C-120 here's what I have of a 857. Please post your pics of either models. True story, I wouldn't hose you guys and not just fishin for
