illinilefttackle 399 #1 Posted September 8, 2016 Hi Guys- I'm back again looking for clues on the re-assembly of a Raider 12- with Electronic Ignition. I asked questions before & got help with a good wiring diagram. Except the model I'm working on doesn't seem to fit any diagram I have seen. Model 1-1310 ( if I remember right) its a Kohler 12 hp K-301. It has a coil that mounts on the air covers with 4 bolts and has a spark plug wire coming out & a blade terminal on the bottom. Under the air covers there is a module mounted on the bearing case with 2 wires coming out of it marked "I" & "A". the "A" goes down and back to the rectifier- the "I" goes to the front under the coil. Can't tell if it was ever connected there. I have a home for all the wires in the tractor- except this one. Does it go to the coil as it shows in the diagram? ( it shows a wire coming from the "I" terminal of the ignition switch-but this wire comes from the module not the switch. The diagram that looks right shows a start switch with a "M" terminal for Magneto. The diagrams also show solenoids on the tractors- this one does not have one- heavy wires go directly to the switch. Any body got any pictures- or advice- I don't want to ruin these Electronic Ignition parts-Thanks for any first hand advice-or model specific info- Is this Tecumseh Ignition on a Kohler Or a Briggs type (Magnatron).- Thanks- Al OH YEAH- I forgot- this tranny has 1 1/8" axles- do they use # 22 woodruff Keys? 1 Share this post Link to post Share on other sites
953 nut 70,667 #2 Posted September 9, 2016 I presume you already have this diagram, but just in case, here it is. 1 Share this post Link to post Share on other sites
illinilefttackle 399 #3 Posted September 9, 2016 Thanks- I've got that one- Al Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #4 Posted September 9, 2016 Fom the Kohler service manual. The 22 ohm 1/2 watt resistor sounds like a good idea. Would not be so confusing if the "to ignition switch or coil assembly" in the last picture read to ignition switch and/or coil assembly Garry 2 Share this post Link to post Share on other sites
illinilefttackle 399 #5 Posted September 9, 2016 (edited) Great work - I agree on the wording. I have a black wire coming along the frame from the ignition switch under the engine and coming out by the fuel pump. I tested it with a continuity checker- it goes to ground when switch is off, but open all other positions, just like a Magneto system has or the shut off wire to a Briggs Magnetron Coil. I'm assuming this goes to the blade connector on the coil-BUT- does the "I" wire from the trigger module go there also? I will have to think about that for a bit- let me know your opinion please- I;m going to see if I can find a 22 ohm resistor in the circuit somewhere. Thanks for your time- Al Edited September 9, 2016 by illinilefttackle Share this post Link to post Share on other sites
oldredrider 2,554 #6 Posted September 9, 2016 As noted on the drawing, the switch wire and trigger wire connect to the bottom post on the coil. 2 Share this post Link to post Share on other sites
illinilefttackle 399 #7 Posted September 9, 2016 Thanks- seems to say that- tune in for results at a later post- Al Share this post Link to post Share on other sites
953 nut 70,667 #8 Posted September 9, 2016 @Aldon did a thread a few weeks back that will serve you well on this subject. 1 Share this post Link to post Share on other sites
illinilefttackle 399 #9 Posted September 9, 2016 Wired it up - both wires to the terminal on the coil- cranked it over- SPARKS like crazy! Thanks guys!- Al 1 Share this post Link to post Share on other sites
953 nut 70,667 #10 Posted September 9, 2016 27 minutes ago, illinilefttackle said: SPARKS like crazy! 1 Share this post Link to post Share on other sites
ohiofarmer 3,543 #11 Posted September 9, 2016 (edited) Actually, those Raider 12's have three different systems, according to my service guy. I bought a Raider AKA Electro 12 that has points ign, but does not have the common beer can coil. Instead, the coil [or possibly magneto?] is integrated into the stator group behind the flywheel but still functions as a coil. Since these are NLA, he said that i could clip the wires, add a Kohler coil [which has a resistor] and a different switch like the more common units have. As an alternative, you could also add a switched just for the coil but it is likely that you could forget to turn it off and burn up the points or coil. i could be wrong about some of this, so I invite comments and corrections. Edited September 9, 2016 by ohiofarmer Share this post Link to post Share on other sites
