cafoose
Just got a garden plow today
cafoose
I just got a garden plow off Craigslist today for $50. :banana-dreads::banana-dance::banana-blonde::banana-jumprope:   I never had one before so this will be a new experience for me! The separate original bracket in the picture was bent so the previous owner made a new one, installed it, and then he fixed the old one.
953 nut
:text-coolphotos:   You may want to back off on the depth adjustment a bit, the way it is set now you will be going down about two feet. Just play with it a little and you will be ready for the next plow day.
cafoose
How do I set the depth adjustment? By the turnbuckle? How far do I adjust it and which way do I turn it?    :scratchead:
953 nut
Yes, the turnbuckle will set the depth. Jack the tractor up and put a piece of 6X6 or whatever you have under each tire to elevate the tractor  five or six inches off the floor. Attach the plow to the hitch and let it down, now adjust the turnbuckle until the bottom of the plow is resting level on the floor. The skid plate at the back will keep it from wanting to go deeper.
There have been a few threads on this over the past couple of years with photos.
cafoose
:text-thankyouyellow: I will check the threads out. The turnbuckle seems like it hasn't been adjusted in years so I guess I need to use some penetrating oil and/or heat to loosen it. I'm thinking of using it on my 876 since that has a slot hitch. The cable is broken so I will need another cable before I can try it.
953 nut
@wheelhorseman1000 is a vendor and makes the cables, they are first class, I bought one and am very pleased.
  • Similar Content
    • David414
      By David414
      I don't have any prior knowledge or experience with this plow as I will be a first-time user. Need some help please.
      I brought this well used plow, which I believe is a Brinly PP-500 series as the exploded part view seems to match up with my plow.
      Completely disassembled the plow, removed all rust, primed, painted, (wheel horse red of course) and re-assembled with new fasteners.
      Having trouble with the coulter blade, as it doesn't seem to fit this plow? Please refer to the pictures below.
      It appears to mount only one way, but it seems too big for this plow.  Do I have the right size coulter blade?
      What am I am doing wrong? Also is the front yoke assembly mounted correctly?
      Thanks
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • Bbo44
      By Bbo44
      SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
      52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
      48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
      48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
      MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
