Similar Content
			By Gravely Horse
I’ve got a 520xi with a ch20 kohler. It has 982 hours. It runs fine, but after seeing this valve train kit on eBay, I was wondering if there is any harm or need to throw one in it. Any one have insight into this?
			By CasualObserver
Owners manual for the two cylinder snowmobile engines.
12 pages 1.38MB
1970 399 Safari snowmobile model 9-0041 - 2-cylinder
1970 440 Safari snowmobile model 9-0051 - 2-cylinder
1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
			By CasualObserver
Owners manual for the Single cylinder snowmobile engines.
12 pages 1.33MB
1970 295 Safari snowmobile model 9-0011 - 1-cylinder
1970 309 Safari snowmobile model 9-0021 - 1-cylinder
1970 309W Safari snowmobile model 9-0061 - 1-cylinder
1970 355 Safari snowmobile model 9-0031 - 1-cylinder
1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
			By Berco
Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
			By gfullz
Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
