slpalmer
C-160 Restoration Project
slpalmer
Greetings all,
Here is my 1977 C-160 in mid-restoration.  She purrs like a kitten.  They don't sell blades for this deck anymore (as far as I could find) so I bought some close and had a machine shop drill the extra holes to make them fit.  I should see tomorrow how well that works out.
https://goo.gl/photos/1sJsDsajAcSTK3Kk9
I'm in SE TX, looking for garden plow and tiller attachments for this sweet girl.
Hope you enjoy the pics!
Stephen
  • Like 6
JERSEYHAWG /  Glenn
Hey Steve,    :wh:           :text-welcomeconfetti:        :wh:    ,    welcome to red square. Sure appreciate the pictures of that wonderfull gal you are working on. A real sweet machine. Don't be a stranger.
Glenn
roadapples
Love the C160`s and    :WRS:
slpalmer
I know aftermarket replica stickers are available.  I that color of red still available for body paint?  I do have a few rust issues...
Stephen
Edited by slpalmer
Completion of comment
Achto
Early IH red is a close match. It is available from multiple paint companies.
slpalmer
Thanks Achto!  When I get ready to get the body sandblasted and re-painted I'll remember that!
Stephen
DougC
Hello and :text-welcomeconfetti:   Enjoy the forum!   :handgestures-thumbupright:
JERSEYHAWG /  Glenn
Stephen
Terry, vinyl guy, is a vendor on this site. he has the decals and is GREAT to work with. Most, if not all here use him and his first class product.
Glenn
slpalmer
20 hours ago, Wishin4a416 said:
Welcome to Red Square!! I restored the same Tractor a couple years back. Well almost, mine is an 8 speed. Good Luck. I got my Decals off of Terry as most of us do here.
That is a beautiful C-160!  Decals from Terry?  Which body paint did you use?
Stephen
Wishin4a416
Rustoleum Regal Red in spray bombs for small parts and quart can for big parts through a gun.
JERSEYHAWG /  Glenn
Regal Red is my choice to. Only I do the rattle cans, lol. A dozen at a clip.
Edit: btw Jack, that was a sweet job. A+
And Steve, others choose Rustoleum sunrise red.
Glenn
Edited by JERSEYHAWG / Glenn
WheelHorseNut
On 7/25/2016 at 3:12 PM, slpalmer said:
Greetings all,
Stephen
Stephen, That's a great tractor and what a nice starting point!
How'd the blades work out?
@Wishin4a416 Man, that came out awesome!  Just gorgeous!
slpalmer
The place I took the blades didn't open Monday.  We had some bad storms here Sunday night / Monday morning and I think he took some damage.  I'll be bt there tomorrow to pick them up and I'll update here.  I took the 1 remaining damaged blade I had for them to use as a guide so I have high hopes.
Stephen
slpalmer
Guess I need to find a shop with a drill press and diamond tipped bits.  The guy I took the blades to burned up 2 hardened steel bits trying to drill the blades and only got 2 pilot holes done in one blade.
WheelHorseNut
Wow -- didn't realize they were that tough to drill through.  How about a press with a punch and die set?
slpalmer
Working on finding another shop.. will update once I know.
oliver2-44
I also used Rustoleum Regal Red on my 312-8 restore and enamel paint Hardener. From tractor supply. Also used decals from Terry
Good to see another Texas member
Edited by oliver2-44
  • Similar Content
    • Natejc_98
      By Natejc_98
      I’m looking for the recommended process to restore old wheels from grinding to sanding to painting. Also what tools are preferred in the process?
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
