Ramennoodles1971 2 #1 Posted July 23, 2016 Hello! I have an older wheel horse riding mower. I had a flat tire. I took tour off to fix it. Put it back on and note the tire is rubbing frame. Seems like the other wheel is farther out as well. Please help! 2 Share this post Link to post Share on other sites
953 nut 66,695 #2 Posted July 23, 2016 Is the rim on the same direction as it came off? Is the same amount of axle showing beyond the hub? 5 Share this post Link to post Share on other sites
russellmc301 601 #3 Posted July 23, 2016 might be somthing you didn't relize you did wrong 1 Share this post Link to post Share on other sites
Aldon 4,832 #4 Posted July 23, 2016 24 minutes ago, 953 nut said: Is the rim on the same direction as it came off? Is the same amount of axle showing beyond the hub? my guess is that the hub slid inward on the axle a bit. 4 Share this post Link to post Share on other sites
stevasaurus 23,716 #5 Posted July 23, 2016 The end of the axle should be flush with the end of the hub. 1 Share this post Link to post Share on other sites
stevasaurus 23,716 #6 Posted July 23, 2016 (edited) The end of the axle should be flush with the end of the hub. Edited July 24, 2016 by stevasaurus 1 Share this post Link to post Share on other sites
ACman 7,728 #7 Posted July 23, 2016 , @stevasaurus have you been drinking to much pickle juice ! double posting or is that to make sure he checks both sides 10 Share this post Link to post Share on other sites
SylvanLakeWH 31,559 #8 Posted July 23, 2016 2 hours ago, ACman said: , @stevasaurus have you been drinking to much pickle juice ! double posting or is that to make sure he checks both sides Yeh that. Yeh that. 4 Share this post Link to post Share on other sites
857 horse 2,588 #9 Posted July 24, 2016 Is the rim on backwards now?? Share this post Link to post Share on other sites
Kegler 68 #10 Posted July 24, 2016 Valve stem goes on the inside. 1 Share this post Link to post Share on other sites
TDF5G 2,074 #11 Posted July 25, 2016 On 7/23/2016 at 4:02 PM, stevasaurus said: The end of the axle should be flush with the end of the hub. 1 Share this post Link to post Share on other sites
953 nut 66,695 #12 Posted July 25, 2016 On 7/23/2016 at 3:45 PM, Ramennoodles1971 said: Please help! @Ramennoodles1971, what have you found? Share this post Link to post Share on other sites
