BigRedGrizzly
1970 GT14 Resto
RubyCon1
On 8/29/2016 at 6:16 PM, BigRedGrizzly said:
 I'm lost. I painted everything so I wonder if I insulated a ground somewhere. Could it be that the engine sitting on the newly painted frame? I don't think so.
This is the pathway current would need to follow to get from the hood support to the engine and then the starter.
paint over any one of the connections between the body panels and you lose ground to your block
BigRedGrizzly
Hi all.. The rectifier/regulator has
been claimed.
BigRedGrizzly
Hey guys... Tonight was the night. I  opened the fuel valve, sprayed a couple shots of starter fluid into the air intake, and turned the key. It fired right up. A couple more shots of starter fluid and it was running on its own. Pulled the throttle in and out a few times and it responded perfectly. I pushed the hydro lever into reverse to test the trans and I got nothing. Moved it forward and got nothin. I was just about to get upset that it wasn't working when I thought I better check the parking brake. Yep, it was engaged. What relief. Now to complete the final assembly and the finishing touches/touch ups.
Edited by BigRedGrizzly
  • Like 9
roadapples
We never doubted you for a moment....:handgestures-thumbupright:
857 horse
Not for a moment.......If you throw somthing.....just throw it out the door....lololollo
BigRedGrizzly
I need to put another coat of paint on the hood so I just temporarily installed it for these pics. Once the hood is dry I'll be applying the decals. I also need to get a bulb for the right rear tail light. @Aldon When you get a chance, would you mind showing me the threaded rod you used for the hood latch? I thought I had sourced an original part but I didn't. So, I plan to use your method.
Here are some more we pics. We love pics.
  • Like 6
19richie66
Looks great Grizzly. I so want me a gt14. One day.
Aldon
Just used all thread from Hardware store. With threaded end caps.
The steel is not tempered or as strong as back in the day so the latching does dot provide as much of a solid feel as the original.
As as these tractors move slowly I feel no need to go to a larger diameter to get the stronger spring action. However I had considered going to slightly larger.
The hardware stores here have these drawers with all sorts of things that would have been Neely impossible to find before Internet. I used to be a frequent McMaster Carr customer and they are my last resort these days. A couple purchases a year and the remainder either Amazon or local Ace.
BigRedGrizzly
Got it... Thanks, Aldon
Here's a vid of my daughter driving the GT14
Aldon
Looks like a pro!
BigRedGrizzly
I took your advice and grabbed some threaded rod 3/16" in diameter. It was labeled 1/4-20. I cut a piece 15" and placed through the hood and the latch. I used those cap nuts as you recommended to give it a clean finish. I jut used some zip ties on either side of the latch to keep it centered on the rod. Thanks for the advice.
Aldon
Looks great!
Walt
On 8/6/2016 at 10:47 PM, BigRedGrizzly said:
Ok... I figured it out. I am missing a bracket. I think I'm going to make one.
Check with WheelHorseMan1000 in the vendors if you haven't made 1 he sold me reproduction of the original.
BigRedGrizzly
Hi Fellas... All the lights, switches,and the electric PTO seem to be working fine. It took me a while to figure out the key had to be rotated back one notch to the accessory position to work. I kind of figured it out by accident when pressed the cigarette lighter in and it popped out. It was HOT! So I guess the ground issue was only to the engine.
   I can't get that darn steering wheel to budge. There's always one major hiccup in a project. This is a big one too b/c I can't get a new dash on with out cutting in half. I would hate to have to do that. On a good note I hooked up the 3 point and that seems to be working fine. I'm looking for a draw bar I can put a ball on.  I'm thinking about ordering the 7 hole draw bar and the draw bar clips from this place.
http://www.xtrememotorworks.com/
Here's a vid of the 3 point.
BigRedGrizzly
Trevor drives the GT14
BigRedGrizzly
Hi Fellas... Well I finally started pulling the plow together and getting it ready for snow. The articulating bracket which allows the blade to turn left and right was bent badly enough to not let it turn completely to the left. The pin to secure in the position wasn't even close to the hole. A little work with a Mapp gas torch and a sledge hammer and we were back to straight again.
  I recently sold my 1993 CR250 which I know I will regret soon.
I made some money on the deal which afforded me to finally purchase a welder.
I got a Lincoln Electric 140 Mig which has the option to run gas. Currently I'm just using the .035 flux core that came with it. Never had an official lesson except for what YouTube has to offer which is quite a lot actually. My to favorite channels are ChuckE2009 and Welding tips and Tricks. Excellent resources.
Anyway... so the plow I got was set up with some custom brackets to attach it to the rear axle. It was making use of those clevis pins to hold it in place. I happen to have the proper attachment bracket but it would not fit with those clevis pins. So the answer was to remove the pins and weld the rod in place which I did. Just little welds in case I choose to make it removable again. Here are some pics of me doing that.
Got some tire chains on order.
Problems with pics
Achto
I highly recommend switching over to the gas. I'm sure by now you have experienced the nasty splatter that comes with using flux core wire. When you use solid wire with the gas your welds will come out a lot cleaner and you will have less weld spatter. Note: When using the gas wind can be your enemy, wind can blow the gas away from your work causing your weld not to stick or burn in correctly. I sometimes am forced to close the door on the garage in order to get a decent weld.
19richie66
:thumbs: gas all the way and never look back. No comparison.
BigRedGrizzly
Thank you for the tip. I definitely want to go the gas route b/c that spatter is a PITA. Do you use the mix or the straight gas?
Achto
I use an argon / carbon dioxide mix for most common welding. Your local welding supplier should be able to set you up, just tell them what type of welding you plan on doing. Example: to weld stainless you will need to change wire and gas. I have a medium size tank, my rental on the tank is around $45 a year. Most of the time when I need to refill they will just exchange tanks with me. Plus side of renting is that I don't have to pay for inspections or updates on the tank at an inopportune time.
Edited by achto
BigRedGrizzly
I recently purchased a welder and began teaching myself how to use it. I'm using a Mig with fluxcore filler. I needed to make a bracket that would connect my plow to the lift point on my tractor. I used a 1/4"X3/4" piece of steel, drilled a hole for some bolts to go through and welded them in place. I then drilled holes in the bolts for the retainer spring clips. I love doing these little projects that make a BIG difference. I also painted up my 3point. These are for my GT14.
FatJackDurham
Looks awesome. I bought a GT 14 last week, and want to do the same. First, I am getting the engine running right with a carb tuneup.
your post is inspirational!
ztnoo
If you are looking for more inspiration concerning GT 14 restorations, check this fantastic thread out:
BigRedGrizzly
I couldn't wait to this mounted up so as soon as it dried I put it together.
  • Like 7
Aldon
Happy Birthday!
:hbd:
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
