Deadguy 864 #1 Posted June 17, 2016 This is bad, isn't it? 2 Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted June 17, 2016 It's nothing that money can't fix! 3 Share this post Link to post Share on other sites
Deadguy 864 #3 Posted June 17, 2016 It is a 1972 Raider 10 with 1" axle shafts. I was able to find replacement axle shafts on eBay, but 1" hubs are evading me. Well, other than the guy on eBay that is selling them for $100! I have found several hubs on various websites that sell parts, but none of them say what size axle they are for. Does anyone know what Wheel Horse or Toro axle hub part numbers are for the 1" size? Thank you! Also, I thought these things were supposed to be tough! This busted while pulling a chisel plow through soft ground. 1 Share this post Link to post Share on other sites
N3PUY 1,031 #4 Posted June 17, 2016 And it's ONLY 44 years old! That didn't just happen. That hub has been loose for years to be that beat! When did you last tighten the set screws? 6 Share this post Link to post Share on other sites
Deadguy 864 #5 Posted June 17, 2016 That would have been last summer when I changed the tires.... Share this post Link to post Share on other sites
Digger 66 3,528 #6 Posted June 17, 2016 7 minutes ago, N3PUY said: That hub has been loose for years to be that beat! X-2 ^ 2 Share this post Link to post Share on other sites
857 horse 2,588 #7 Posted June 18, 2016 (edited) Digger,,,,,,,,,,i had the same thing happen this winter on one of my 857...Snow pushin,,,,Stump pullin ,,meanmachine 1967 tractor... So,,,,,,,,i need just a hub...you need a hub,,,Im going to the BIG SHOW next week,,,i was gonna buy a single......i can get a nice pair.just as easy split the $$$$ with you,,,if that works......send me a PM......i will give you my # ,,,,,,,,,,,,,,,, Alls good................. Howard 857 Horse n VA Edited July 15, 2016 by 857 horse 4 Share this post Link to post Share on other sites
Achto 31,913 #8 Posted June 18, 2016 (edited) 4 hours ago, Deadguy said: Does anyone know what Wheel Horse or Toro axle hub part numbers are for the 1" size? I believe the part # is cast right into the back of the hub. Looks like 3979. Chances are that your set screw became loose and caused this damage. Edited June 18, 2016 by achto Share this post Link to post Share on other sites
C-101plowerpower 1,606 #9 Posted June 18, 2016 10 hours ago, Deadguy said: It is a 1972 Raider 10 with 1" axle shafts. I was able to find replacement axle shafts on eBay, but 1" hubs are evading me. Well, other than the guy on eBay that is selling them for $100! I have found several hubs on various websites that sell parts, but none of them say what size axle they are for. Does anyone know what Wheel Horse or Toro axle hub part numbers are for the 1" size? Thank you! Also, I thought these things were supposed to be tough! This busted while pulling a chisel plow through soft ground. maybe @racinfool40 has some. otherwise it think i have one laying around Share this post Link to post Share on other sites
Racinbob 12,996 #10 Posted June 19, 2016 Loose 'for years' didn't cause that. Decades of use and fatigue did. It's possible the set screw was over torqued and caused a hairline crack in the casting and finally it just gave way. Anything can and will break given enough years. It's no reflection on the toughness at all. There will be many at the big show and it looks like Howard will get you fixed up. No need to pay the ridiculous Ebay prices. 2 Share this post Link to post Share on other sites
moe1965 774 #11 Posted June 19, 2016 I have a 1 inch hub off a raider 10 if your are interested Share this post Link to post Share on other sites
Howie 900 #12 Posted June 20, 2016 I have a tractor here that I bought last fall with some damage similar. Had to tear it down anyway and hubs were sort of high for used ones so I bought the cutter to put new keyway in. Put the sleeve in 90 degrees from the old one and put in a new keyway. Since i have a small press it made this possible and I had seen this done at my place of employment. Got a piece of 1/4 inch copper and made a piece to mimic the key clamped it in welded the axle and then turned it down. I know everyone can't do this but since I could I went ahead with it on mine. 1 Share this post Link to post Share on other sites
mid60's 93 #13 Posted June 25, 2016 Had that happen to my Commando 8. Probably decades of use and being loose. Tightening only put off the inevitable. Took the complete trans. to the machine shop where they cut a new keyway on the opposite side of the axle and a replacement hub and I was good to go. That was 10 years ago. Still going strong. 1 Share this post Link to post Share on other sites
Deadguy 864 #14 Posted June 25, 2016 Just now, mid60's said: Had that happen to my Commando 8. Probably decades of use and being loose. Tightening only put off the inevitable. Took the complete trans. to the machine shop where they cut a new keyway on the opposite side of the axle and a replacement hub and I was good to go. That was 10 years ago. Still going strong. unfortunately, there are cracks in the axle radiating out from the mashed up key way, so the whole end of the axle is structurally compromised. I did find replacement axles, and next is the fun step of removing the transmission, cracking it open, and pulling out the differential assembly. 2 Share this post Link to post Share on other sites
stevasaurus 23,716 #15 Posted July 3, 2016 Piece of cake. It is harder to find those hubs then it is to open and fix that transmission. BTW, how is it going?? 1 Share this post Link to post Share on other sites
Deadguy 864 #16 Posted July 3, 2016 Howard got me hooked up with a new hub from the big show. I found replacement axles too. I will be moving in a few weeks, so once I get my new shop set up, I will probably do a full transmission rebuild on that tractor, as long as I have it off the tractor. In the meantime, here is a picture of my other two horses to enjoy! 3 Share this post Link to post Share on other sites
stevasaurus 23,716 #17 Posted July 3, 2016 Let us know when you start. I have some videos that will help you rebuild the trans. I also have a Raider 1972. 2 Share this post Link to post Share on other sites
857 horse 2,588 #18 Posted July 4, 2016 On 7/3/2016 at 2:36 PM, Deadguy said: Howard got me hooked up with a new hub from the big show. I found replacement axles too. I will be moving in a few weeks, so once I get my new shop set up, I will probably do a full transmission rebuild on that tractor, as long as I have it off the tractor. In the meantime, here is a picture of my other two horses to enjoy! Got Toms hub all ready to ship......just waiting for the Holiday and the rain it brang to pass...................Tom.....you gottah come to next years show...!!!!!!!!!!!!! 1 Share this post Link to post Share on other sites
ohiofarmer 3,435 #19 Posted July 5, 2016 On 7/3/2016 at 3:20 PM, stevasaurus said: Let us know when you start. I have some videos that will help you rebuild the trans. I also have a Raider 1972. Well, I wonder if this is like a celebrity dying, [coming in threes]. I have owned my raider 10 for a couple of months and noticed that low range has some lag time and the wheels take a bit of time to move. High range is fine and dandy. Maybe in its previous experience the tractor pulled some heavy stuff in low range. I lost a tree and used it to pull a heavy tree section closer to the fire to make it easy to cut up and burn right away. Now the low range problem is worse and I will need to tear it down this winter. Video sounds like a great idea. 1 Share this post Link to post Share on other sites
stevasaurus 23,716 #20 Posted July 5, 2016 The videos are available in 2 places. On U-Tube by clicking the link at the bottom of my signature, and by going into the "Reference" Section (Transmissions) on the main page of this site. If anyone needs any help, or has questions...just start a thread and ask. 1 Share this post Link to post Share on other sites
Deadguy 864 #21 Posted July 14, 2016 Thanks to Howard, the Raider is back together again! I also received a little something extra in the deal.... Thanks again! 3 Share this post Link to post Share on other sites
857 horse 2,588 #22 Posted July 15, 2016 Tom......Im glad that machine is getting back into the action..... and so you know....everyone that has responded to this post is are ,,,backs against the wall....true Blu solid gold......the information is unending....and very accurate.. the guys really like pics of progress....and mind you ,,,,they will Howl like coyotes if you don't ..... 11 months to go........piece of cake !!!! 1 Share this post Link to post Share on other sites
Deadguy 864 #23 Posted July 15, 2016 As per request, here is a photo of the wheel back on my wife's Raider. Enjoy! 2 Share this post Link to post Share on other sites
