north
C81 where to start
north
I just picked up a c81 with a mower deck and plow for $300..not sure if it runs but looks good.  I washed it up and 1st step is a battery...any suggestions on how I should proceed or what to look for?  Or if it was worth $300?
thanks
Edited by north
  • Like 5
Rob R
Think you did GREAT C81 my favorite tractor....not so much for the mower... but it is a bear for pushing snow and doing chores around the property, good fuel, clean carb and a good set of points and you will have one (in my opinion) one of the best machines made.
  • Like 8
SylvanLakeWH
:text-welcomeconfetti: to the WH "C" club!
AMC RULES
    :text-coolphotos:     :handgestures-thumbsup:
:WRS:
Retired Wrencher
North. :WRS:  Looks good in picks. Get a battery from Walmart or Home Depot same price. just to see if you have spark. Then maybe change the fuel lines and filter. Buy good fuel line $3.00 to $4.00 a foot, start it  and see where you are at. Let us know how things are.
Tankman
Three hundred bucks well spent! Check, change fluids, fuel, cleanup and you'll be on your way!
Nice Horse and I bet, ready rarin' to wo...wo....WORK!  :handgestures-thumbupright:
Racinbob
That looks like an outstanding deal. As already suggested I would do a tune up, fuel lines and filter, fresh fuel, engine oil, flush transmission and fresh oil.:)
DougC
Hello and :text-welcomeconfetti: north!   Enjoy the forum and the new  :wh:.
roadapples
As others have said, good buy. plow and chains are worth half that, and....  :WRS:
JPWH
:WRS:
TDF5G
I'd say you gotta a sweet deal on your horse!  She's definitely worth putting a few $ in to get her going.  Looks complete except for air filter and cover.  And you'll need a couple of mower deck wheels.
With a little diagnosis you should have her runnin' in no time.  After you get a battery hooked up, check for spark and compression.  Then go through the fuel system.  I don't know how long it's been setting, but I would check the shutoff valve in the bottom of the fuel tank for rust and crud before putting any gas through it.
:WRS:
Edited by TDF5G
north
Fresh fluids and a new battery!  Onto the mower deck
IMG_2904.MOV
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
