LFR 39 #1 Posted April 27, 2016 So the tractor sat for 2-3 years and other than maybe some points sticking or the coil or condenser bad what is a known problem on these horses, every tractor has a problem. Is the fuel pump go bad if not used much? And what can I expect with charging, does the rectifier go bad or if things are working should it be fine? Also how tough is the 8 speed transmission, or are the shift spring going to need attention?! I expect some belt slippage and that's stuff I can fix! Also looks like it needs front wheel bearings too! Just curious on what I know I will need to tackle! The tanks smells ok so I think if I put in some seafoam and a new fuel filter I'll be ok?! Thanks anyways guys! 1 Share this post Link to post Share on other sites
Tankman 3,528 #2 Posted April 27, 2016 (edited) Too many "if's" to guess. Was the Horse stored indoors? Outdoors covered or uncovered? Can you turn the engine, by hand, doesn't jam? How's the engine oil level? Trans oil? I would probably take the Horse, low bucks. Then a thorough work over. Fuel filter and fuel lines. Drain the fuel tank, start with "new" fuel. Any boat slips nearby? Might find some non-ethanol gas. Clean all 'lectric connections. And more. Was this your Horse? Take a peek-a-boo at this thread. Edited April 27, 2016 by Tankman 1 Share this post Link to post Share on other sites
Retired Sparky 526 #3 Posted April 27, 2016 You can find wheel bearing at Fastenal or Motion Indust. I was lucky I have an active dealer near by. Share this post Link to post Share on other sites
pfrederi 21,306 #4 Posted April 27, 2016 Just drain all the gas out of the tank and lines. Start with fresh 1 Share this post Link to post Share on other sites
LFR 39 #5 Posted April 28, 2016 I'm not to the gas yet but I'll do a full flush! So what I found is that my starter was stuck so I pulled the air shield and freed it up with dry lube and not it springs all the way back! But I don't have spark! So I'm missing 1 ingredient as I do have compression and will have gas! So it's either the points, the coil, or the condenser, checked and filed the points no luck, so I'm buying a spark plug and then bringing over a coil and condenser! If it still don't have spark it's the points, I haven't done one in a while but I popped the cover and they opened! So other than these I think I'm going to be in good shape? Share this post Link to post Share on other sites
Lost Pup 187 #6 Posted April 28, 2016 I use what i call a gas iv to start up suspect tractors. Its a plastic liquid soap bottle with a threaded nozzle on one end and i have one hole in the side near the bottom. I fill the bottle about half way with fresh gas holding my finger over the hole then put the cap on with a long piece of hose slipped over the end nozzle. The other end goes to the carb inlet. The bottle has a wire loop taped to the bottom so it can be inverted and hung up higher then the carb. A simple gravity feed and i used it many times to get the stubborn engines started quickly to be sure you have a good runner before pulling and flushing the tank and changing the lines. 3 Share this post Link to post Share on other sites
LFR 39 #7 Posted April 28, 2016 Yeah I have a old cub cadet tank that I use it has its own filter and shut off and I do the same thing! Can someone tell me if the condenser is supposed to be on the negative side, I can't remember?! Pretty sure it does Of the coil I'm talking about Share this post Link to post Share on other sites
can whlvr 994 #8 Posted April 28, 2016 I would check the seat switch maybe put a bypass wire Share this post Link to post Share on other sites
LFR 39 #9 Posted April 28, 2016 Yeah but it turns over so I don't think that's it! Because it just wouldn't turn over if it wasn't working would it? Share this post Link to post Share on other sites
farmer 1,081 #10 Posted April 28, 2016 @Lost Pup, sounds like you work in casualty, do you have a nurse standing by? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #11 Posted April 28, 2016 8 hours ago, LFR said: Yeah I have a old cub cadet tank that I use it has its own filter and shut off and I do the same thing! Can someone tell me if the condenser is supposed to be on the negative side, I can't remember?! Pretty sure it does Of the coil I'm talking about Yes the condenser goes on the (-) side of the coil. The battery power goes to the (+) side of the coil. Easy way to remember - Most times the condenser connects to the points. The (-) side of the coil goes to the points. The condenser does not care which end of the (-) wire it goes to. The body of the condenser needs to be grounded to the engine or chassis metal. New paint can prevent a good clean ground connection. Garry 4 Share this post Link to post Share on other sites
LFR 39 #12 Posted April 28, 2016 Ok! My points don't look horrible so I'm going to regap them at .020 and then put my new coil and condenser on! And also a spark plug Share this post Link to post Share on other sites
rmaynard 17,644 #13 Posted April 28, 2016 10 hours ago, LFR said: Yeah but it turns over so I don't think that's it! Because it just wouldn't turn over if it wasn't working would it? The starter circuit does not go through the seat switch, but the ignition does. Both do go through the PTO interlock switch. 1 Share this post Link to post Share on other sites
Lost Pup 187 #14 Posted April 28, 2016 (edited) 3 hours ago, farmer said: @Lost Pup, sounds like you work in casualty, do you have a nurse standing by? My daughters coined the phrase, we picked up a non runner for a silly price and instead of pushing it did a little triage. Got it running right in front of the PO and drove it on the truck. He was shocked. I have a few sets of jumper wires , ignore the tractors wiring and just wire the ignition hot to the battery with the jumpers, jump the starter direct , starting fluid and the gas iv and see what happens. Just pull off one of the jumpers to kill it or ground it out to shut it down. Saves times guessing over the wiring and safeties problems. Edited April 28, 2016 by Lost Pup 3 Share this post Link to post Share on other sites
farmer 1,081 #15 Posted April 28, 2016 Sorry for going but now I'm getting images of Ghostbusters l need less Share this post Link to post Share on other sites
LFR 39 #16 Posted April 28, 2016 I won't do that! So in other words if I still don't have spark it could be the pot interlock switch? Cani bypass the pro interlock switch if I still don't get spark? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #17 Posted April 28, 2016 Do you have a test light or a voltmeter? Connect it to the coil (+) terminal and chassis ground. Turn key to RUN position and you should get 12 volts. Now turn to START and you should still have 12 volts while cranking. Connect tester to the coil (-) terminal and chassis ground. Turn key to RUN. When the points are open you should have 12 volts. When the points are closed you should have 0 volts. So if cranking the motor with pull rope or starter the above should happen. It may happen too fast to notice. Remove the spark plug and turn the motor over by hand using the flywheel. The test light or voltmeter should show this on/off cycle. If you don't get the 0 volts the points may be dirty and not making electrical contact when closed. Polish the contact surfaces with a point file or nail file. Drag a strip of white paper between the contacts until it comes out clean. Garry 2 Share this post Link to post Share on other sites
LFR 39 #18 Posted April 28, 2016 I have plans to use a test light tonight for that I filed the points with a dollar bill yesterday so the test light should tell me when I am getting power all I know is that it should blink on and off! They looked ok and weren't burned so I may replace the coil and condenser for good measures and then start testing I should have spark tonight if all goes as planned Share this post Link to post Share on other sites
Pullstart 71,520 #19 Posted April 28, 2016 Filed the points with a dollar bill? Are you in the HVAC industry? We taught plumbers to clean flame sense rods on water heaters with dollar bills (50's or 100's if that's all they have) because they will polish instead of scratch. 1 Share this post Link to post Share on other sites
LFR 39 #20 Posted April 28, 2016 im in high school! But my grandpa taught me how to! I went and bought a new TestFlight because my old one burned out and the alligator clip finally broke! And I bought a fuel filter too! Hopefully I can finally get spark tonight and then I would be in business! 1 Share this post Link to post Share on other sites
LFR 39 #21 Posted April 28, 2016 Ok so I replaced my coil and have power on positive and negative, I clean the points and set the gap with a wire connector because my feeler gauges are gone! For some reason on the - side I have straight power and not flickering power? But the points are spotless? So what is my problem? Unless they are gapped wrong? What is my problem? I HAVE SPARK!!!!!!!!!! Yay! Now it's time for gas, hopefully the fuel pump isn't bad! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #22 Posted April 28, 2016 For some reason the points are not grounding the coil when closed. Try a jumper from the wire on the points to the chassis ground or engine block. That should take the coil (-) to 0 volts. If it does not do it the wire from the coil (-) to the points has a break in it. If it does do it the point contacts are not making a connection to ground. Try sticking a small flat screwdriver between the contacts to see it that completes the circuit. Try grounding the coil (-) terminal to prove it can be done. Garry Share this post Link to post Share on other sites
chip61 666 #23 Posted April 29, 2016 Do you have 12v at the coil?? Power in should be on the + side of the coil, condenser and points should be on - side of coil. Share this post Link to post Share on other sites
LFR 39 #24 Posted April 29, 2016 Yay! Major progress tonight! It will be running tomorrow! So I have compression and spark! Now I just need fuel which I would have done tonight but my fuel lines were so hard I couldn't put a filter in them or a **** off valve! So back to the parts store in the morning for line and then flush the tank, add gas and see if I can get the pump to work! How should I prime the fuel pump so the tractor will run, or does it pick it up pretty quick? Share this post Link to post Share on other sites
LFR 39 #25 Posted April 29, 2016 Those stars should say shut not**** Share this post Link to post Share on other sites
