Tomcat1975
Electrical wiring issues
Tomcat1975
I have a 1989 wheelhorse 257-H Model 2217KE02 I need wiring help I can't find a single wiring diagram please help I can find for an 88 257-H but not an 89. Or if anyone can tell me I got 3 wires that come from seat switch orange,white, and a light green which wire goes where or can I just bypass seat safety switch completely.
Edited by Tomcat1975
KC9KAS
:WRS:
Yes, you can "by-pass" any safety switch for trouble-shooting purposes only, but it is called a "Safety" switch for a reason.
Is the wiring on a 1988 not the same as a 1989?
gwest_ca
Welcome to the forum.
1988 and 1989 use the same exact engine spec and the same switches.
The only difference sounds like the color of the wires.
The 111332 switch has 3 terminals. Parts list shows 2 of these switches being used so suspect they make up the transmission neutral switch.
One wire is common to the other two.
Switch at rest joins the common to the other terminal #1 (Other terminal #2 not connected)
Switch depressed joins the common to the other terminal #2 (Other terminal #1 not connected)
This is the only switch in the Glossary of this file on page 3-35
Garry
Tomcat1975
16 hours ago, KC9KAS said:
:WRS:
Will the seat switch them make the pto not work properly the reason I ask is because I'm trying to determine which switch it is the seat switch,pto switch or ignition switch what happens is it starts up just fine but when you turn key to off it stays running and when I turn pto switch on it won't come but pto light comes on so I didn't no if because the seat switch is safety switch as well if that's my problem but that's where I'm at stumped
And I think the only difference is colors of wires like Gary was saying
I've been rebuilding these mower engines for years now but I'm terrible when it comes to wiring so basically What im asking is there a simple way to test this wiring problem for dummies
gwest_ca
I don't know this model and can only go by the 1988 detailed wiring diagram so going to think on paper here.
This model uses a magneto type of ignition which is self powered. The lone ignition wire simply grounds the ignition to shut the engine OFF. Do not allow and battery power into that ignition wire because that will burn up the coil.
Treat this as two separate problems - igniton won't shut off and pto not engaging.
The starter circuit uses the ignition switch (START position), pto switch (pto OFF), and neutral switch (trans in neutral) to energize the starter solenoid. All that is working
The ignition in the START position uses the ignition switch (M terminal not grounded), pto switch (pto OFF) and the seat switch (operator in seat opens the contacts that ground the ignition wire)
Most times a seat switch controls the ignition. If the operator falls out of the seat with the pto OFF the seat switch in this case of magneto ignition grounds the coil and the engine quits. On this model the operator must be in the seat to have ignition when starting the engine. The ignition is working but is the operator in the seat when starting?
The ignition in the RUN position uses the ignition switch (M terminal not grounded), pto switch (pto ON) and the seat switch (operator in seat opens the contacts that ground the ignition wire) With the pto ON the pto switch passes the ignition wire on to the seat switch. If the seat switch is open (operator in seat) the ignition wire is not grounded. If it were closed the ignition would quit. If you get out of the seat does the engine quit as it should?
Sounds like the seat switch is working properly but your answer to the 2 questions should confirm it.
The problem may be the single ignition wire from the engine. If you can identify it take a jumper and ground it to the chassis and/or battery (-) negative - the engine should quit. The ignition switch and the seat switch both ground that ignition wire so my guess is the wire is the problem and not the switches.
When you find the ignition problem it may solve the pto problem.
One thing that is common to both problems is the chassis grounds. The body of the ignition switch should be grounded so check that first. Also make sure all the chassis metal is grounded.
Let us know what you find.
Garry
KC9KAS
Just print out the wiring diagram. Follow each wire from end to end.
You can make notes on your printout as to what color your wires are if the are different from the print.
You just need to make sure that each wire is connected exactly where it should be connected and no discrepancies are found.
You may find bad connections or wires terminated at the wrong location, or not even connected!
Good luck and keep us informed!
  • Similar Content
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • grasscuts
      By grasscuts
      Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
    • jakester
      By jakester
      hello all I'm a new owner of a 312-8 tractor, have starting problems, came across a very small, what I believe is a relay between the battery and the dash,its about 2/3rd size of a cube of sugar silver on the outside blue on top with a hole bout the size of a pea, theres 6 pins with wires connected to it on the bottom do not know what this is any thoughts? I cannot determine the exact year of this machine for there is no tag anywhere only tag on engine kohler magnum md #m12s   ser# 170370459  spec#  471527  I figure its mid to late 80s to early 90s. of all the wiring diagrams ive looked at it does not show any thing like what I just described also can that little circuit board be removed that's like a test point for idiot lights? any help would be appreciated  jeff
