M1N1ON
So the grandfather in-law is a self proclaimed hoarder. He has two barns full of old tools, trailers, and junk. I recently purchased a new house and we were talking about getting a riding lawn mower to both mow and plow snow. He says he has an old mower in one of the barns and if i can get it out, i can have it!
Low and behold i dug out an old Wheel Horse Raider 9! It is complete and stock. It was in decent shape but could for sure use some TLC. I got it home and here is my progress...
Here it is after i pushed it around the garage 20 times while i moved in and got settled. It had wheel weights and flat tires.
25777549983_5f002f0fc7_z.jpgIMG_2770 copy
And as i started digging into it.
26313690261_edfcb83b01_b.jpgIMG_3076
The battery obviously is shot and the wiring harness has been chewed on by something. I ended up cutting out some of the wires because they had rusted together.
26354006286_1ae996d98a_b.jpgIMG_3077
26379888595_2cfcf8d74b_b.jpgIMG_3078
Pulled the head off to see if it was all rusted out before i tried turning it over. If it was seized i was going to put a motorcycle motor in it. Oh well...
26354006116_e84ba19c56_b.jpgIMG_3079
26354005976_150a35bc36_b.jpgIMG_3080
I got tired of cleaning the head by hand and cleaner. I got this angle die grinder on sale from HF. Also picked up some fine abrasive pads for it. Worked great.
25775068734_4acbbb51f2_b.jpgIMG_3411
25775068654_287a081333_b.jpgIMG_3412
Learned these things can get a little squirrely. Set it down on the bench and it turned on and grabbed my glove. Luckily it just burnt my skin a bit.
26354005376_cd466f76b6_b.jpgIMG_3413
Got the tank off and started looking at the wiring. It is a mess. Its clearly been spliced into 5 different times and chewed into. I am trying to find a wiring diagram but everyone I find has a different layout.
26287560082_dfd56fd41b_b.jpgIMG_3414
26379887705_30fd7d73cb_b.jpgIMG_3415
So two questions, is there supposed to be play in the rear-most pulley on the trans? and does anyone have a good wiring diagram i can use?
  • Like 4
WNYPCRepair
Found this in the file section
You might want to search through these results, I found some service bulletins, etc. later on in the results
http://www.wheelhorseforum.com/search/?&q=raider%209&type=downloads_file&page=1
Edited by WNYPCRepair
roadapples
Good find, and    :WRS:
953 nut
:WRS:
:text-coolphotos:               Love to hear of :wh: being passed down in a family. Sounds like you have a good grasp of what needs to be done.
Glad to see there is lots of room in your garage, these little RED stallions are a bit addictive.
dells68
Good luck with the motor.  Techy's can be a little finicky sometimes.  Not that I'm partial to Kohlers or anything;).
Ed Kennell
:text-welcomeconfetti: to the  :rs: M1n1on.        :text-coolphotos:
That's a great project tractor. Was your wife's Grandfather the original owner?   Is he involved in the redo?
 Don't let these Kohler lovers scare ya.        LogoYesBlack.gif    rules
dells68
If I have to be honest, I had a gocart when I was a kid that had a Tecumseh on it and I couldn't kill it.  It was one tough little motor.  Dad eventually sold it to someone else who also got some good out of it!
Achto
First, :WRS:. It looks like Brian found you a diagram already. As for the pulley there may be slight play of the shaft in and out. There should be no side to side play of the shaft and no play of the pulley on the shaft.
M1N1ON
26373934346_10cf698547_c.jpgUntitled
This much?
Also the pulley looks busted. How difficult is this to remove and replace?
26145071790_71e1d36546_c.jpgUntitled
Thank you! The Grandfather is not involved, he lives about an hour away from us in the summer time but migrates down to Texas for the winter. He has been getting a kick out of the pictures I've been sending him. He is the original owner, it was parked in the barn since 96'.
He also has an old cub cadet "mid size" lawn tractor. It pains me because he parks it wherever he is done using it in the yard, flips the seat over and walks away. Leaves it like that all winter, full of gas, battery connected, middle of the yard. Comes back in the spring, flips the seat over, and it starts right up. I take every precaution with all my equipment and half the crap doesn't work come spring.
M1N1ON
Anyways got the belt off (ish), figured out the rear pulley was damaged as described above. Not sure how i will fix that. Also need to get the mower deck off?
26391986916_1cfa1caf70_c.jpgUntitled
Found this junk...
25815140913_60076f6e23_c.jpgUntitled
Then here is where i got mad, broke some stuff, cussed a lot, and walked away. I needed to get the flywheel off because the wires coming out of the charge coil where sheafing so i was going to splice into those and put some heat shielding on it. I was messing around with the flywheel and looking up online how to get it off. I rented a puller for Vatozone and while using it, busted part of a fin off. So then i saw online how a guy just used a pry bar and it popped off. Well.... i was already heated and P.O.ed so i tried it and well....
25813085454_90ac6becf9_c.jpgUntitled
Does anyone think this will still work? Should i just replace it? I didn't want to have a ton of money into this project and these all look expense...
M1N1ON
Just went out to go look at it again. Now i just want to start it on fire.
Irv
:WRS:  While I admire someone taking on a project like that, unless it is a tractor that is sentimental to you, I would tend not to try to bring that one back. Looks like it's been used and abused and it will cost you lots of bucks to restore into a running, dependable unit. I would look for a decent C or 300/400 series tractor with the attach-a-matic and much more readily available attachments (decks, blades, blowers). Be patient and you should find one at a reasonable price and in much better condition than your raider.
M1N1ON
I respectfully disagree? There is no rust, all the parts are there, and aside from the charge coil and rear pulley, I'm not going to have a whole lot into it. Plus it as free and i am not going to let it (being the tractor) "win".
The cheapest i found one on CL was $700 and it was a bucket.
Edited by M1N1ON
  • Like 5
dells68
Dr Jekle?  Mr Hide?  You there?  Just kidding!  I too get frustrated with projects, get aggravated, want to walk away, then cool down and am ready to go again.  In all due respect, I agree that you are looking at a major undertaking to turn this machine into your weekly mower.  Not saying it can't be done and well worth the time. Find a cheap crapsman or something similar to use while you slow down, really take time to do a proper tear down, and enjoy the process of bringing her back to life.  She'll be a great tractor, just gonna take time.  Ask lots of questions here and you'll find the help and answers you need.
Ken B
Nice project. I think you are looking at it the right way, at the current moment you are way ahead of the game as you are into the tractor for zilch. If it turns out the old Techy is flat worn out I would head over to Grandpa's place and do a little rummaging. Who knows, there might be a good engine layin around free for the taking. My advice would be to not throw a bunch of money into the current engine, a little possibly but not a whole bunch. Upgrading the current engine to a Kohler is no big deal and won't be too expensive. Once you take a little simple green and the power washer to your Raider she will clean right up, I don't think it was left outside thru the years. I think she has been used but for its age she looks pretty darn good.
  • Like 6
Achto
The pulley is held on to the shaft with a set screw. It will probably take a little prying to get it off after you loosen the set screw. Should be able to replace the pulley with any cast or steel pulley of the same size ID and OD. I don't recommend an aluminum pulley, they usually don't hold up.
This much?
It does look like the pulley has walked out on the shaft. Does it line up with the clutch / idle pulley, or has someone spaced the clutch / idle pulley out to compensate? Does the belt seem to line up good from the engine to the trans & idle pulley? Normally the trans pulley is closer to the casing, but modifications may have been made.
Ed Kennell
:text-yeahthat: I agree with Ken.....The Raider  definitely  needs to be saved especially  with it being a family one owner tractor.     It may not be cost effective to save the Tecky, but it can be replaced with a Predator for a couple bucks.
Predator Engines 69730 6.5 HP (212cc) OHV Horizontal Shaft Gas Engine EPA
Cole J.
Interesting project you got goin' I'm working on a 72 charger 10 and have got quite frustrated with it at time, in my opinion if you get mad at walk away for a little while cool down, come back if a few hours or the next day, it will be there when you come back. Its better to take it slow and do everything correctly than fast and messed up, because that may cause problems later on that are even worse that the first. Good luck, have fun with it. Always ask question, there's never a stupid question when it come to these thing. Nice tractor keep up the good work :handgestures-thumbupright:
M1N1ON
Why does everyone think the tecumseh is junk? Aside from the charge coil that i jacked up, everything is tight and together. I purchased a gasket kit and impulse pump diaphragm on amazon already for a couple bucks. I fully expect this motor to fire up once i put it back together.
Anyone have their 2c on the charge coil? will it work? Do i need a new one?
WHX??
It's not that we think the Techys are junk we just know that parts are ..well can be hard to find and pricey. For what you would have in it you could easily do a repower. It is definitely a labor of love to get it going. as for the coil..yeah I think you trashed it.... Good news on the pulley a member had one in classifieds not too long ago.. see if I can find it for you.
Here it is ...might be what you need maybe @RedRanger can help you out....
RedRanger
Thanks for the mention.  Yes, I have the Mott's!
M1N1ON let me know if you want it.
Steve
M1N1ON
Anyone know where i can get the charge coil? is there a conversion for these?
oldredrider
If a member here doesn't have one, check on eBay.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get a big diesel swap.
      Thanks,
      John
    • sjoemie himself
      By sjoemie himself
      You know those people that have too many projects?? Yeah me neither!
      Another tractor added to the heard. Case International 585 with canopy/sunroof.
      It's a 60-ish horsepower tractor with very limited electronic gimmicks. Has a nice tight turning radius. It was built in Doncaster from 1985 to 1990 and the hourmeter says it has ran 4700 hours since then, I'll take that with a grain of salt though.
      Plan is to use it for all kinds of jobs around the house and barn/stable for my gf's horses.
      Ofcourse it is not a new machine so there are things that will need looking after but all the basics are there.
      Pictures you say? Sure!
    • PWL216
      By PWL216
      I have for sale a 1984 C-105 with deck and Snowblower. I got this as part of a package. There’s no battery and I haven’t tried to start it. I’m selling it as a project. The deck has one spindle out, but with it, as prior owner claims bearing was replaced. The snowblower has the flag and looks to be in very good condition. All but 1 tire holds air. The mower is complete. Includes mule drive. The extra hood (c-175) you see in the picture can go with the tractor for an additional $50. Thx for looking.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
