moe1965 774 #1 Posted March 20, 2016 Help... I just finished taking apart and painting a raider 10 i took the trans out and painted it I removed the gear selecters to paint them . I reassembled and now I only have high range gears The high low selector seams like it is jammed.. any suggestions? 1 Share this post Link to post Share on other sites
pfrederi 21,274 #2 Posted March 20, 2016 Do not force it as you can bend the hi-low fork. Is it back on the tractor or still on the work bench?? You need to spin the gears a few times then try again. 2 Share this post Link to post Share on other sites
stevasaurus 23,861 #3 Posted March 20, 2016 What year is your Raider...or the Model Number? BTW...Welcome to Red Square. Share this post Link to post Share on other sites
Retired Sparky 526 #4 Posted March 20, 2016 Hello and Do you smell the grease, you have arrived. You're in good company. Share this post Link to post Share on other sites
moe1965 774 #6 Posted March 20, 2016 (edited) Here is what happend. When i assembled it one bolt that bolts the The trans to the frame was to long. It is a through hole into the trans. The bolt hit the high low lever not letting me select between them. In the process of just finding that out I did braak a gear. I had a few choice words. The trans is totally dissembled. My issue now is are there replacement parts available? Here is a picture is the broken gear. modle number is 1 0301 7 from what i can figure out its a 1972 Edited March 21, 2016 by moe1965 more info Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,519 #7 Posted March 21, 2016 Sorry to hear that. Here is the parts list Garry 1 Share this post Link to post Share on other sites
stevasaurus 23,861 #8 Posted March 21, 2016 Looks like part # 7206 gear reduction. Send a PM to "racinfool40" (Mike)...I'll bet he has what you need. @racinfool40 Share this post Link to post Share on other sites
moe1965 774 #9 Posted March 21, 2016 Thanks I will do so Share this post Link to post Share on other sites
