Theroundhousernr
Snowblower Electric Chute Motor
Theroundhousernr
    So its been awhile for me to make a formal post. Been taking on more at work and just been so busy but i still check in from time to time. I have been thinking of ways to add electric chute rotation to the blower. Seen it all been done before but not much on the tall chute blowers. So I hope this isnt boring.
  I wanted three things,
  -relability( no need to make a simple design turn into a failure , specially when your out blowing snow)
  -symplicity
  -little to no modification to the blower itself
  Came across a surplus supply of gmc electric seat motors on Amazon for $15.00. Read reviews. Motor is reversable, can be taken apart to switch output shaft orientation (also meant machining of the shaft possible), and had a nice 1/4" hole mounting fixture. Figured if it lifts someones fat rump then it should be up to the task of spinning my chute. So i ordered it....
  Again I didnt want to damage any orignal parts so I went to my local fabricator shop and picked up some 3/8 cold rolled steel. Which is the same thing wheel horse used for the shaft the worm is on. So now I must adapt this wierd non standard worm thread shaft from the seat motor to the 3/8 rod used for the worm drive on the blower. This envovled a good friend of mine and his lathe. Took a 3" by 1" round stock stainless and but it in his 3 jaw chuck. First drilled the 3/8 hole all the way threw. Left the piece in the chuck to hold center and drilled, I believe it was, 29/64 for the seat motor shaft to a depth of 1.5 inches. So now we have an adapter with the 3/8 hole 1.5 inch depth and a 29/64 hole with a 1.5 inch depth. Added a set screw for either side and that piece was done.
 Now we put the seat motor shaft in the chuck and turned it to fit the hole with a slip fit of about .002 of an inch plus or minus. The joke was , we are not building a rocket ship to get to the moon but if any garden tractor could , it would be a wheel horse.... Wah WAh
 Took my new fancy parts home with me to finish the rest. After careful measuring I cut the 3/8 stock down to size and drilled a hole for the role pin that holds the worm to the shaft. Next I cut my seat motor shaft down to size and ground a flat on the shaft for a firm place for the set screw to grab. Remember this is a threaded shaft not smooth. Shown in pictures below. My seat motor required disasemble anyway to swap the shaft to come out the other side for chute clearance. The motor is offset from the gearbox and it caused the motor to hit the chute when chute was rotated hard right. I assembled everything and all was left was to drill a 1/4" hole for mounting. Measured where I wanted the hole , drilled hole and used 1/4" threaded rod for a fasener and a few bolts..
  I think it turned out great. I added a rubber cover out of rubber roofing to protect it from the weather. It has plenty of speed lock to lock on the blower. Should be reliable. Best part of all is it can be returned to a crank in minutes incase of failure and nothing original was damage to the blower itself but a 1/4" hole! Something yet to be determined are some kind of stops so to not tear up anything incase the motor gets stuck in drive or someone else uses it and doesnt realize. I will add pictures of the setup and video if I can to show speed of the chute. Also if anyway wants measurements, amp draw of motor, or any question feel free to ask. Might even make some more adapters if anyone is interested. Next post I will show will be how i wired everything. Hope you enjoy!
https://youtu.be/3Zsim1ihip0
https://youtu.be/9sUim0PQlOo
  • Like 7
WNYPCRepair
That is some excellent work. I just ordered the motor, I hope mine turns out half as nice as yours.
For stops, figure out a mount for a couple of these, and a couple of small tabs on the chute.
microswitch.jpg.829578fa693c36d273d27619
Edited by WNYPCRepair
Ed Kennell
Nice....got a link to the motor Brian ?
Theroundhousernr
Seat Motor Link   Here ya go. The exact one Ed.
WNYPCRepair
Yep, same one I ordered
Theroundhousernr
  I considered some type of limit switch like that but wonder how well it would survive the conditions of snow and water. Then I got to thinking about reed switches transistors and relays. I can find nice weather proof reed switches but havent found many weather proof limit swithces. This all goes into play with how I intend to wire this thing and control it which I will get into next. I will also be mounting a electric linear actuator for chute deflector. The current wiring is only temporary to test it out and it worked wonderfull. Except , I was in a rush and forgot to put loctite on the set screws.... Oh well. All that took was an allen wrench.
WNYPCRepair
I was just sitting here earlier trying to figure out how to weatherproof them.
On the other hand, that exact switch is located in the wheel well of aircraft to tell them whether the gear is up or down, and while the gear is down, they are exposed to weather, at 500 knots, so maybe we are overthinking it.
In the meantime, I'll see if I can find a weatherproof switch
WNYPCRepair
Wow, this is about all I could find under $100. And they only have 1 in stock
http://www.amazon.com/Bridgeport-BP-11630131-Weatherproof-Switch/dp/B00KIUXEPU
They aren't cheap (same as Amazon), but I found more
https://www.professionalgearco.com/shop/bridgeport-bp-11630131-prcn-weatherproof-micro-switch/
Theroundhousernr
Did you check mouser or digikey? There electronic surplus supply houses. Might check them tonight. Those from amazon seem ok but have no reviews and only one instock which most likely means there is nothing there. Im glad someone else has the bug besides me;):handgestures-thumbupright:
At least they get air blown dry from time to time:ychain:
Edited by Theroundhousernr
AMC RULES
Works really nice too...     :eusa-clap:
once you get it all  put it all together in a kit, sign me up.
Theroundhousernr
In my video, you can hear a clicking noise. That was some nicks in the worm gear. Once I filed those down and adjusted the lash between the gear and the blower chute. The noise was gone. Also in the video, I was using a model train transformer to run the motor in a pinch. Not enough amps from the small transformer. I will take a video of how it is now hooked up to the battery. Its not really anymore faster. Just more responsive, but big improvement non the less..
gwest_ca
Many years ago I added a backup lamp to a C-120 8-Speed. Mounted a switch intended for a door or window in a security system to the side of the hoodstand next to the shifter in the reverse position. Then clamped the other magnetic half to the shifter. The switch has a common terminal plus normally open and normally closed terminals. This is powered by the light circuit.
A relay was added that is powered by the battery. If the lights are off the backup lamp won't come on. Weather has never been a problem but if it was my plan was to install the switch in a plastic container or plastic tubing and seal it up. The magnet would still control it.
A pair of these could be used to limit the chute travel.
Garry
  • Like 4
WNYPCRepair
Garry
That's a great idea, Garry!
shallowwatersailor
I could be wrong but if you use the limit switch, how do you reverse polarity to have it run in the opposite direction once it shuts off? Would it be run through two relays, one for each direction?
Edited by shallowwatersailor
WNYPCRepair
You would need two. One at each end of travel, to cut power to that side of the circuit when it reaches the switch. Power is still available on the other side of the circuit to reverse direction
I was sent a message by another member who said he worked for TI and the switches they made for this were sealed. He can identify himself if he wishes, not my place to do so.
Anyway, I searched for a picture of an A-4 nose gear door, since I remember using the switches there. After seeing the picture, my memory was jogged and he is correct. Those switches were inside a sealed box with a protruding arm with a roller bearing on the end.
Pullstart
My wood splitter was once a scissor lift.  The guy who built it used one of the position switches from the lift to activate a "home" position for the auto return on the ram.  It's a foot pedal operated split, you lift your foot and it returns to the switch.  Maybe an equipment company would have that same type of switch for a scissor lift?
Pullstart
duplicate post oops
Edited by pullstart
Pullstart
and again... refreshed my browser!
Edited by pullstart
shallowwatersailor
So using limit switches means four wires for the control circuit with the relays as well as two wires for the the load circuit. It might be easier to do a mechanical clutch. It could be as simple as using a piece of rubber hose and clamps to allow slippage.
WHX??
I was thinking some kind of dial switch ala the old tv antenna rotator type? Just turn the dial to where you want it and it stops automatically. Just an Idea & food for thought....time to brouse the electronic supply houses for the right switch???
Ed Kennell
I like this idea John.  Limit switches will only save the worm from hitting the end of  the gear.  A clutch will also save the system if the chute jams.
I'm also thinking an electrical clutch...low amp fuse or breaker ?
shallowwatersailor
I have the makings for the chute rotator. I just was trying to "engineer" it so that I could go back to the manual crank if the motor failed. It means duplicating the gear, shaft and bracket.
A simpler method to add a clutch would be a cordless drill mounted in the cab that is equipped with a clutch driving the rod. Not the WOW factor but do-able.
doc724
I do like the idea of using a surplus seat motor.  Last year I toyed around with the idea of using a small geared down DC motor and even measured the torque to turn the chute and the typical RPM needed to mimic how fast you could turn it by hand.  (of course, I either did not save the calculations or I cannot find them)  All of these motors, were, however more that $15.  My conclusion was that if you kept the rotational speed about equal to a manual turn rotational speed, then limit switches were not needed.  Now, if you were using something that would spin the chute really fast and you would not be able to react in time to prevent damage, then limit switches (or clutches) would be desirable.
BTW, does anyone know what car seat motors use to prevent damage at end of travel?
WNYPCRepair
No need for relays. Motor has a forward and back circuit, ground and positive for each. You supply power to the forward circuit, the seat moves forward, Apply power to the reverse circuit, the seat moves backward. For my example, substitute left and right for forward and back.
You hit the control switch to move left, the chute rotates left until it hits the left side limit switch (NC), which kills power (opens the switch) to the left side circuit. Since the circuit is now open, the chute will go no farther left.
The right side switch is still in the NC position, so when you use the control switch to move right, the chute will turn right until it hits the right limit switch, which then opens and kills power to the right side circuit.
As soon as you started moving right, the left side switch returns to the NC position, so you can reverse at any point, until the chute opens the NC switch and stops further travel. If both limit switches are closed (chute is somewhere in the middle), you can use the control switch to move in either direction.
If that isn't clear, I could do a diagram. I am not an artist, but I should be able to get the point across.
  • Like 4
Ed Kennell
Makes sense, or cents, or scents to me Brian. But then Me being a Hydro Power guy, I have to convert all my electronic stuff to a fluid to be able to grasp it.
Volts = pressure
Amps = flow
Ohms = friction
closed switch = open valve
open switch = closed valve
Clear as water....:confusion-confused:
Edited by ekennell
  • Like 4
  • Similar Content
    • FarmallFarmer09
      By FarmallFarmer09
      I recently purchased my first wheel horse with a number of new attachments, And included in that bundle was a Wheel Horse snow blower. I would love to use it, But as it seems, Its missing a few key components to use it. Its missing the 2 side caster wheels, Along with the lift rod. does anyone know where i could potentially pick up either of these things?
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
    • jebeli
      By jebeli
      Lets make a deal. The whole collection for $3000 or one tractor and half the items listed below for $1500.
      I am moving to town so am willing to do a partial trade for a wheelhorse more approproiate for a suburban lot- lawn ranger, surburban models, bcs walking tractor, other?
      I could possibly deliver or meet half-way or ship.
      Both tractors run great and are in good working order. Second owner of both machines. I work with these machines everyday so they are not perfect but are, in my opinion, in excellent shape.
      42in high-shoot snow blower
      42 in rear discharge deck
      Snow blade
      Front mount deck hanger with 42in side discharge deck
      30in lawn seeder
      Brinly single bottom plow with cleavis or sleeve hitch
      50in grader blade
      Extra transmission
      36in rear tiller - leaks a little
      Full set of tire chains for each tractor
      Various body pieces
      7.5 cubic ft pull behind cart - may need tires
      Extra set of rims
      All required belts, pullys, brackets, manuals, too much to list.
