BenTheWheelHorseMan
Westendorf FEL?
Pierrepont
There is a used Simplicity loader (Made by Kwik-Way) on CL in the Syracuse / Auburn, NY area.
I believe it is very similar to the Wheel Horse Kwik-Way loaders
Edited by Pierrepont
Snowmobileaddict
You may want to follow this auction. You can see that the price written in paint pen on the side of the bucket was $1,250 at one point in time.  Freight might be $250 to your location.  Looks like he's about 550 miles from you.  Fastental is great for cheap freight quotes.  Its become a side business for them.
http://www.ebay.com/itm/331760836614?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
46F865F9-6C4C-4FFD-864A-4097AC2DC0A9_zps
Here is the owner manual for the Rhino loader.
http://support.servis-rhino.com/RhinoManuals/operator/F-3649C%202405%20Loader%20OPS%20PUB%2003-12.pdf
Specs included in the literature indicate the total attachment weight, ready-to-mount is 457 lbs.
The loader will lift 500 lbs.  This is on par with a Kwikway.
Edited by Snowmobileaddict
BenTheWheelHorseMan
That one looks pretty good. That is an auction that I may follow a little and see if I can't accidentally win a bid.
BenTheWheelHorseMan
Well, westendorf did not give me a number even because they said that my tractor was not in their fit schedule. I doubt that it ever will be so I suppose that a Westendorf loader is not in the cards for me.
WNYPCRepair
They didn't even reply to me
Snowmobileaddict
Well
its a good price for a simplicity legacy.
that loader uses onboard hydraulic pressure and onboard controls.
to put it on a horse it would be BYO pump and BYO spool valve
thats $300 easy
  • Similar Content
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • mmmmmdonuts
      By mmmmmdonuts
      This is more a general question but has anyone used a quick attach system for a GT FEL? I was thinking of adding one to my loader to use start switching between my bucket and forks ( hopefully a blade soon). If you did how did you do it? Did you use the SSQA system? My biggest concern is adding a bunch of extra weight to a GT loader but I really hate swapping between the two. Pictures would be fantastic.
    • mmmmmdonuts
      By mmmmmdonuts
      With a front end loader for these tractors how important is a ladder type subframe? Does the cross piece in the front have to connect where the towers are? Can the frame where the towers are just mount to the frame and go back to the transmission or is that cross piece critical where the towers mount? Could it be set further back with the same effect or would it not be the same? I know it is important to go back to the transmission so if you hit something you don't snap the frame, but how critical are the cross members?
    • r1jakecfd
      By r1jakecfd
      Didn’t get to swap the loader out for the 44” 2-stage snowblower and cab on the 520-H before the Christmas Day storm. I had the engine out to redo the top end (decarbon, clean and reseat valves, New gaskets, New fuel pump, tubing, filter, plugs and properly seat camshaft Welch plug) so no time to switch over before storm. It’s just another excuse to use the loader! Merry Christmas everyone🌲🎅🏻
    • Dan693
      By Dan693
      Never saw one before so I had to build it. 200 lbs of rocks and gouged out an old stump. No fail. The little son-of-a-buck wouldnt quit. I love it.
      The little LR will never plow a field but dont ever say its not robust enough for ground engagement. Thats nonsense.
      Just another example of how they built lawn equipment in the 60's. I have a bone stock LR from '66 that I would never change.
      Great to have both a Jekyll and a Hyde.
