JoeM
Do you name your tractors?
roadapples
Mine only have names when they wont start. Nothing I can use here..
  • Similar Content
    • Joe Reese
      By Joe Reese
      518H Project/Roller Cash - As Is Has last compression/spark last i checked, currently not running. Gauges work when hooked up to battery and engine turns over freely, Has new fuel pump & carb. Comes with original carb & parts
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Stratman
      By Stratman
      This is a (1-Owner) 42” Single Stage snowblower attachment (low hours of use) . This is the Attach a Matic system that will fit WHEELHORSE- Toro 5Xi series tractors , as well as New Holland GT (18 , 20 & 22) series machines . It comes complete , with Factory Manual , chute direction crank arm & support , every clip , nut n bolt , bracket needed to mount it to your tractor . Only used on paved surface / Rock Solid ~ Light surface rust only , No holes or weakened metal , nice skid wear pads .
      The (dedicated) Mule Drive & Drive Belt are also included . It works Great , however I now have a plow truck , and no longer need this attachment for my mower .
      Note ; I also have the W/H 75lb wheel weights & tire chains , that can be worked into the deal (if needed) !!!!!
      For additional purchase information ; Please Reply with a name & phone number / I will respond with with my Contact info ; Thanks 4 lookin’ / P.S. I can skid this all up & drop off @ FASTENAL for your Pre-Arranged shipping .
    • Monstrosity
      By Monstrosity
      Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
