JoeM
Do you name your tractors?
roadapples
Mine only have names when they wont start. Nothing I can use here..
  • Similar Content
    • DevonianHorse
      By DevonianHorse
      Hi all, on a 1977 Wheelhorse C-100 (Belgium made), I have a question
      My Wheelhorse hood opens really far- it does eventually stop but I don't think it is meant to go this far and that there's a piece missing.
      In this photo, there's a hole you can see (near the middle of the pic, 1/3 down) and the same on the other side of the hood mounting part of the frame- I assume some sort of bar is meant to go between them that the hood latches at the base will catch on and this stops the hood dropping further when opened? If this makes no sense sorry- I have simply always assumed that the hood is meant to open at a right angle from the front, but having seen videos, I can see most stop before that.
      Does anyone know the part I need, or would two bolts, one on each side, do the job? Mine has never had one, so I am unsure.
      Thanks!!
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Monstrosity
      By Monstrosity
      Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
    • Vaughan32850
      By Vaughan32850
      New to this forum, Let’s see what other wheelhorse’s are in the UK, I’m in South Wales.
      RJ-58
      Lawn Ranger
      Commando 8
      C-120
      C-101
      C-160 Auto
