378Pete
1960 Suburban help please
378Pete
I have a 1960 suburban 400. Can anybody tell me what fluid belongs in the transmission and how much of it? Do i pour in top plug until it comes out of side plug under axle? I have used the search function but got multiple answers and left me more confused. Thanks for the help.
Racinbob
Yup, multiple answers because Wheel Horse changed their minds :rolleyes:
The manual stated up to the oil check hole on the side. Do that and you'll be fine.
Then they said 1 1/2 quarts. Do that and you'll be fine.
They call for SAE 90. I use 80w90. Some go heavier. Do any of that and you'll be fine.
Oh yea, please ignore the blurb in the original owners manual about how to shift while moving. Do that and you won't be fine.
  • Like 4
stevasaurus
You can not go wrong with what has been stated.  You want something that equals 90Wt.  To fill, I like to take out those 2 9/16ths bolts that hold on the seat and fenders.  Place a funnel in one of those holes and pour in the oil until it starts to seep out the fill plug by the trans axle...replace the plug and if you want a little more oil in there...add another 2 or 3 oz.  I would say no more then that.  :)
378Pete
Of course now I can't find it but there was a bulletin I found on here that said to use sae 40. Anybody else see this or did I misread something? It was a big list of tractors and stated to not use the 90wt but instead the sae 40. I do know whatever that was in there was thick and heavy. Thanks for the help, I will try to find what I was reading and post
378Pete
1 hour ago, 953 nut said:
   The owner manual for my 1055 calls for 40W in the transmission and that is what it has had for the dozen years I have owned it; no problems at all.
http://www.wheelhorseforum.com/files/file/1221-tractor-1965-855-1055-da-om-ipl-wiring-snpdf/
That is what I saw when I was looking. I am assuming that there is more than 1 correct answer.
stevasaurus
Your suburban has the 3 piece transmission...really a completely different animal from the 2 halves transmission in like the 1055.  One big difference is the bronze bearings for the outer axles and the differential carriage in the suburban #5010 trans as opposed to ball bearings and needle bearings in the newer trans.  The 2 piece trans has all needle bearings except for the #1533 ball bearing holding the differential.  The 3 piece uses all open and closed ball bearings.  I think the heavier 90wt oil would be better in the suburban trans...just because of the bronze bearings by themselves.  :)  I think you would want the heavier viscosity.
WHX??
I pull the shift lever out to dump it in, that way I get to check the setting of the dog point set screw. I have my 5010's done up with a magnetic plug so in my royal analness I can change it. Probaly won't have to considering how they get get used but what the heck it was cheap & easy.
378Pete
On 12/10/2015 at 10:22 AM, stevasaurus said:
Your suburban has the 3 piece transmission...really a completely different animal from the 2 halves transmission in like the 1055.  One big difference is the bronze bearings for the outer axles and the differential carriage in the suburban #5010 trans as opposed to ball bearings and needle bearings in the newer trans.  The 2 piece trans has all needle bearings except for the #1533 ball bearing holding the differential.  The 3 piece uses all open and closed ball bearings.  I think the heavier 90wt oil would be better in the suburban trans...just because of the bronze bearings by themselves.    I think you would want the heavier viscosity.
I do believe that the heavier viscosity was used for the last 55 years so I played it safe and filled with the 80-90.
  • Similar Content
    • giant_g2
      By giant_g2
    • jmack
      By jmack
      I’m looking for a transmission dipstick to a D-180. Let me know if you see one.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
