tommyg
Simple repair? Hah!
tommyg
I knew is was going to take a little effort to replace the manifold on my D180, but I had no idea! Holy smokes! I should have just planned on restoring the thing while I was at it! The good news, though, is that I found that the "T" bracket that supports the steering column was totally cracked in two near the weld. No wonder my steering was sloppy. Got it re-welded and the new manifold installed. Working on putting everything back together. I wish I wasn't so anal about making sure every bold makes it back into it's original spot! Just hoping this resolves my front manifold leak. After two attempts at putting new seals (and failing), I came to the conclusion that there must be a hairline crack where the tubes insert into the mounting plate. I'll find out soon enough.
Edited by tommyg
  • Like 7
Mike_Eddleman
Hope mine never leaks. I'll use the bucket method, but a bucket under it and pore it fluid back in the tractor
  • Like 4
slovinski
Wow, you went deep brother.  Glad to hear you found the source of your steering problem.
AMC RULES
Looks like it gave you a workout.  :huh:
DougC
Kinda like having to tear apart the entire house to replace the front door knob...:omg:    I see you picked up all the empty beer cans before you took the picture......  :teasing-poke:      :lol:
tommyg
DougC, exactly! And in the process, you find out the door jamb wasn't attached to the studs! I'm gonna look at it as a blessing in disguise, but my fear right now is that I'll get it back together and the doorknob is defective! Really hoping I've got the leak fixed in the process. If not, you might see the beer cans!
Edited by tommyg
DougC
Well, Ohio is not that far from Iowa. Let me know if a beer run is necessary and I will do my best to deliver and even help you empty the cans. I hope however you have it fixed and the empty cans you show us are in celebration. Either way........  It's Miller Time.       :beer:
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
