Swemill
My D-180 project
Swemill
Unfortunately not allowed to upload more pics here... But you could se my D-180 project if you are interested - with some mods at my site:
http://www.bengan.com/predator/
In the meny to the left - click Wheel Horse. I believe that it's quite unique... =)
Sorry for the only Swedish...
  • Like 4
elcamino/wheelhorse
Sorry I can not read Swedish , but the pictures are worth a 1000 words. Does the Trans Am belong to you ? Thank you so much for sending the pictures.
Regards from here in the USA
Jim Winder
Swemill
Thanks!
Well, It's "only" a Firebird but yes it's mine. =)  Have had it since i was 18, that´s 25 years now.... There has been a lot of projects on that car also through the years. =D
DougC
I took the time and looked at all your pictures and I must say, I am  impressed!   Great job on all your projects............:handgestures-thumbupright:
Pullstart
I like the railing for your home!  That's pretty cool for sure.  Along with the rest of your projects, it's great!
elcamino/wheelhorse
Thanks!
It may only be a FireBird but it is one great looking car. You have put a lot of time and mechanical knowledge in the Firebird.
DennisThornton
"Supporters" upload all they want.
We would love to see your pics!
Holy crap!  I took a few to look at the link!  Wow!
bmsgaffer
:jaw:
I am going to have to get on google translate for that. If you ever have the time, please share all your build stories on this forum! Your builds look incredible!
You can post all the pictures you want by becoming a supporter (its not too expensive) at the top of the page click "Store (Support RS)".
Swemill
Thanks everybody for your nice comments! =)
I will sure consider to be a Supporter next time i have some pics to show.
tommyg
I am really interested in how you pulled this off! This is a weak design with the D series and I had envisioned a coupler like this. Can you share any details? Looks like the hydro pump side is secured by a clamping mechanism of sorts. How about the engine side? Parts machined I assume.
Swemill
Hi tommyg, sorry for the late reply... Yes, the parts are machined! You could see on my site how the coupler looked like as standard. There is also more pics of when it is modified. The pump coupler have i machined some splines in and also cut it in two plus bolts to secure it.
However this coupler didn't work real well.... I put a lot of load on the front hitch and the tractor / frame bends a bit.... which result in forces on the pumpaxle and the axle sealing started to leak oil. The coupler was too tight! Later i remachined / welded it more like the original coupler with a large rubber plate and with more clearance. Now it works well! =)
857 horse
I want you to know......i did read the entire link.....although everyone sends you their best.....
i think the cars are incredible,,,,,,and yes the railing is absolutley off the chain.....All prases to you to your sucess's and well executed projects...
Showed my wife your pics......She wants to know when you will be out of town.....we will just come gets the cars and the house....we will bring 2 big trucks..........thank-you for sharing........
yeah got nice stuff !!!!!!!
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
