Dkphillips
Lawn Ranger 3 speed transmission oil weight
Dkphillips
Since I just got my Lawn Ranger restored I thought I would change the transmission oil. When I look at the Lawn Ranger owner's manual it states to use 40 weight oil but the transmission manual says to use 90 weight oil! Which one is correct? Any information from you Lawn Ranger or transmission guys would be appreciated.
Doug
pfrederi
Many will disagree but either one will work.  I have an L-107 purchased my my father in 1967.  She is still in use and I use her year round (see avatar). 48 years running and no tranny issues. She has run 40wt oil the entire time. Changed about every 10 years Shifts nicely in the cold.......
  • Like 5
Dkphillips
Thanks for the info. Looks like I will be purchasing some 40 weight.
Doug
callum12
why didn't you post this about 2 days earlier!!?
I have loads of SAE 40 oil but i went out and brought SAE 90.
haha oh well, these things happen.
Callum
Dkphillips
Garry,
The link you sent will not open. Some error as usual with some links. Evidently the bulletin says to use 40 weight oil based on other posts.
Thanks,
Doug
Sent from my iPhone using Tapatalk
Garry,
Thanks,
Doug
gwest_ca
Perhaps this is readable
Dkphillips
Thanks for this info. Looks like 40 weight oil is in my future!!
Doug
bob's toy
Well that answers my question as to what weight and type of oil to use in my transmission. Thank you all for the great information..
Dkphillips
Just bought a couple quarts of 40 weight oil today. Did not get the oil changed in the Lawn Ranger yet but probably will tomorrow. Always glad to help someone else "accidentally".
bob's toy
I am a lead tech for Mustang Cat here in Houston and we use a 50wt gear oil in trans and final drive due to extreme wear factors. I think it will work. It gets 100+ in the summer so from what I see every day this is my first choice. The oil in the trans was not bad at all. Looked to have been kept serviced. No rusty oil and no metal at all.Will flush and run soon...almost ready to prime, lots of cleaning yet...
953 nut
:twocents-02cents:     I doubt that a Lawn Ranger or any other manual shift garden tractor will generate enough heat to make a difference, I have 40 in all of mine.
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • Matt_8
      By Matt_8
      I was wondering if anyone knew what wheel weights i would use for my lawn ranger on stock wheels three lug pattern
