T-BONE
transmission stops
T-BONE
I Just got a 99 520h with a 2 stage bermac blower. I paid $500 for it. I already have 98 520hc. So I am familiar with the tractor and transmission so when I was picking the 520h up the tractor moved slow. I  checked under the seat and the linkage was very loose and didn't go to its max strong , , figured that was a issue. When I test test home tightened everything up set the linkage and motion lever linkage   so now when i move the tractor it moved very fast but only if you short period of time. It's like it was in neutral. Also the piston that lifts the blower works sporadic.   Does this all mean it's the pump ins the tranny. Please help.
rmaynard
Did you check the fluid level?
T-BONE
I drained oil and changed oil filter. I put almost 5 liters in it
thanks for for reply
can whlvr
make sure the belt isn't slipping or the drive pulley slipping on shaft
T-BONE
OK. I will have a look. Are these units self bleeding.   I topped up the tranny while running and it bubbles indicating that there is air in system
Shynon
I have to ask what kind of oil did you put in it?
T-BONE
10w30
Shynon
10w30
What brand. Dealer I used to work for told me Valvoline will cause air bubbles and trans to not work correctly. He always used Mobil 1
Edited by Shynon
T-BONE
Really. I used Motomaster  10w30. On sale for 13.99.
so I just took of right side back wheel. Trans fan side. Started it up. Belt looks like it's not slipping. I put it in forward and 1 wheel started to turn fast. I grabbed it and the other one started to turn very fast. . Put in reverse and nothing. I put back it forward and nothing. If it does go in forward it is very slow and I can stop wheel. Also lift doesn't work. Is it possible that the charge pump is done.   Or could it be even worse
Edited by T-BONE
T-BONE
Anyone have any thoughts
stevasaurus
I'm not sure what is wrong with your hydro.  I can tell you that you should be able to grab one wheel and stop it (while the horse is in gear) and then the other side will turn in the same direction...that is what it is supposed to do.  They should do it in reverse also, and the speed should be the same.  When in neutral, if you turn one wheel, the other should turn in the opposite direction.  I would say that there is nothing wrong with your transmission...it is in the hydro part.  :)
We do have some very good hydro guys on site, just have to wait until they see this.  In the meantime, try doing a search.  I know there is a ton of threads concerning hydros...you might find out where to start next.  It does sound like it could be air.
T-BONE
Thank you. What is the best way to bleed these systems
T-BONE
I've been doing som more research and I noticed that on the Eaton 700 that there is a oil add spot on the transmission.   I have only change the oil on the transaxle. (plug on bottom of transmission
Edited by T-BONE
T-BONE
I think I am going to start with bleeding air first. I a going to start off at the hydrolic lift lines and go from there. Any one else have a better idea. Thanks in advance
can whlvr
ok,so first if u have a 520 hc its an eaton 1100 series,it draws the oil from the transaxle,thats the onl place for you to fill,the pump will self bleed,sometimes it takes a bit of running and using the lift,but they usually don't act like you have mentioned,it sounds bad,if the belt is not slipping,the pulley is tight and not slipping on the shaft then its more than likely internal,but I would make sure its not linkage,other then those items its hard to know
T-BONE
I started it up after work . Raised lift. It worked and squealed like like other 520 and then then stopped. I then started to bleed line at the lift. There is a lot of air in the system but it still wouldn't catch. up then bleed the air at the filter return line but it still wouldn't bleed all air out. Do u think it's done :(
Edited by T-BONE
T-BONE
I will also mention that the pulley that the  fan is on is very rusty and the tension spring for the drive belt had a kink in it so I replaced it with a spring that was stronger I would say.  What would be a good indicator that it was slipping if it is covered in Rust but looks as if it's spinning fine
953 nut
You could clamp a pair of Vice-grips on the pump shaft and try to move the pulley by hand, it shouldn't move at all.
Edited by 953 nut
T-BONE
Everything checks out. And I just found an Eaton 1100 transmission and transaxle for 150. I'm gonna get it. shoukd I be looking for anything when I go pick it up. Guy days his engine blew a valve
can whlvr
that's the one thing about the 1100,s theres lots of blown onans so they are out there,it could be air but usually they will bleed them selves
  • Similar Content
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
