chris sutton 610 #1 Posted October 21, 2015 I was wandering what you guys think the strongest wheelhorse tranny is ? unidrive or tuff torque, i'm thinking of upping the HP and wandered what tranny to go with Share this post Link to post Share on other sites
meadowfield 2,737 #2 Posted October 21, 2015 8 pinion from a c series.... Share this post Link to post Share on other sites
DennisThornton 4,771 #3 Posted October 21, 2015 (edited) 8 pinion with 1 1/8" axles but I'll see if I can get more help.... Hey @stevasaurus ! Edited October 21, 2015 by DennisThornton 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #4 Posted October 22, 2015 8 pinion with 1 1/8" axles but I'll see if I can get more help.... Hey @stevasaurus ! the 416-8 is rigged Like that. Hydro wise the eaton 1100, IMHO.Glenn Share this post Link to post Share on other sites
Racinbob 11,919 #5 Posted October 22, 2015 Without question, the 8 pinion with 1 1/8" axles. But you'd be hard pressed considering the physical limitations to shoehorn in more horsepower than the 4 pinion 1" transmissions can handle. Share this post Link to post Share on other sites
chris sutton 610 #6 Posted October 22, 2015 Thanks for all the response boys, its a great help. I'll go with the unidrive 8 pinion Share this post Link to post Share on other sites
Pullstart 66,612 #7 Posted December 9, 2015 Silly question, but if my 8 speed axles are 1-1/8" is it a given that it's an 8 pinion? Originally from a C-101, now in the 502. Share this post Link to post Share on other sites
stevasaurus 23,274 #8 Posted December 9, 2015 56 minutes ago, pullstart said: Silly question, but if my 8 speed axles are 1-1/8" is it a given that it's an 8 pinion? Originally from a C-101, now in the 502. Nope, it could also be a 10 pinion limited slip differential. You can look down one of those two bolt holes on the top of the trans with a flash light down the other one...if it looks like there is 5 bolts holding the differential together, it is a 10 pinion...if it looks like 4 bolts, it is an 8 pinion. 3 Share this post Link to post Share on other sites
baerpath 517 #9 Posted December 9, 2015 On 10/22/2015 at 7:30 AM, Racinbob said: Without question, the 8 pinion with 1 1/8" axles. But you'd be hard pressed considering the physical limitations to shoehorn in more horsepower than the 4 pinion 1" transmissions can handle. Not that hard, if you work at it a 8hp puller can bust them ............................. oops Share this post Link to post Share on other sites
Pullstart 66,612 #10 Posted December 9, 2015 4 hours ago, stevasaurus said: Nope, it could also be a 10 pinion limited slip differential. You can look down one of those two bolt holes on the top of the trans with a flash light down the other one...if it looks like there is 5 bolts holding the differential together, it is a 10 pinion...if it looks like 4 bolts, it is an 8 pinion. wow, so the pot could be even gold-er! I think I'll have to make it a point to tear it down before spring, that break shaft bearing is still loose and still leaks. been dumping oil in to keep it moving while I'm working on other projects around the house.. Share this post Link to post Share on other sites
