Horsing Around RS
Need some help with a C-160
Horsing Around RS
Ok guys I'm stumped. I have a 1975 C-160 and I have a couple problems with it.
1. There is a voltage draw on it some where, even when the key is off. - not a huge problem
2. After the tractor has been running awhile, it turns itself off and cannot be restarted again until it has cooled down. The starter will not even engage. I have replaced the coil and condenser. It has a new battery too.
The system is charging. I asssume it needs a new starter because once it gets warm it no longer works. But I do not know why it would turn itself off.
I am not sure if these 2 issues are related but any help would be greatly appreciated.
chip61
Not sure why it would shut down-I had a tractor that would run great for anywhere from 20 minutes to several hours then shut down. It turned out to be trash in the fuel tank. As far as not turning over, have you checked for current at the solenoid when you turn the key to start?? Also, do you have current at the coil when it shuts down??
squonk
Check the ammeter and connections.
pacer
Find a way turn the engine over by hand - figure this out before it gets hot - Have a socket/ratchet with you to try and turn the flywheel when it stops. Could possibly be "seizing" caused by overheating (clogged cooling fins, bad/old/low oil, etc) If you can turn the motor by hand right after it stops then continue on chasing something else. If unable to turn over until cooled then you have got some serious problems, once an engine seizes it scores the piston, collapses the rings and possibly mars the cylinder wall.
Horsing Around RS
Pacer: Engine does turn over by hand after it stops running. Thanks
Squonk: I will check the amp meter. I guess that could be a draw. Thanks
Chip61: The fuel is clean. Thanks
Thanks for trying to help guys.
chip61
Is the coil polarity correct??
squonk
Everything electrical goes thru that ammeter. I have seen the connections the melted, burnt, corroded ect. Things get hot and break apart.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
