yzf450motoxrider
new tractor 312A
yzf450motoxrider
Just inherited a Wheel horse 312A. I have a few questions. Are there any snow blower attachments for this model? If not is the attachment for the 312-8 compatible with this tractor? Anyone know where I can get mulching blades for it size 17.5in? Also I am considering changing out the engine for a 16 to 20 hp engine will the drive system be able to handle the added power?
Thanks,
Dom
Racinbob
:text-welcomeconfetti:to Redsquare
Blowers for the C, 300 and 400 series will fit. I'm not sure about the mulching blades. The drive train will handle the added horsepower just fine.
yzf450motoxrider
thanks for the info.
gwest_ca
17-1/2" long blades does not sound correct.
How many blades on the deck - 2 or 3?
What is the width of cut?
Side or rear discharge?
Garry
Sparky
Why the need for extra horsepower? The 312 hydro tractors were sold with a heavy duty and a light duty hydro drive system, you should know which you have before adding another 4-6 HP. If you have manual lift then you have the lighter duty hydro (Eaton-700).....hydraulic lift tells you that its the heavy duty hydro (Eaton-1100).
Mike.........
yzf450motoxrider
I wanted the extra power for mulching and a blower attachment. It is the manual lift.
bmsgaffer
Mulching does NOT work well on any wheel horse decks except the 42" rear discharge deck with a recycler kit (closes off the baffles under it). And even then, some claim mediocre performance.
Dont waste your time or money trying to make it work ive already done it for you. :deadhorse:
a (belt driven) power flow bagger will work well but they are hard to find and a bit cumbersome.
yzf450motoxrider
here's a pic. Also the blades are actually 18.5" makes more sense considering the deck is 37".
gwest_ca
Original blades from Toro 109079 is a 2-blade set
Napa 2 of # 7-04724
Oregon 2 of # 91-817
Hole 3/4in. round
18-3/4" long
Have never seen a mulching blade for these.
Garry
dcrage
And you DO NOT need the "power flow bagger" set-up for that deck to bag the discharge -- The 37" decks were apparently designed to generate extra lift/throw -- There is a factory 2 bag collection system with a 3 piece HDPE (I assume) tube system to attach directly to this deck -- Optimally this would be used with a special replacement "high lift" right blade (has extra large fins on the back of the cutting area) -- Special blade is NOT required
12 horses will do all of the cutting/blowing (I am assuming you won't try to run a 2-stage blower) you could possibly want to do -- You will always lose traction before running out of power -- My experience is with a 310-8 which would supposedly be equivalent to your 312-A in that the hydro consumes more power than the geared transmission
Edited by dcrage
bmsgaffer
:text-yeahthat:
Of course you would have the 37" deck, the one exception to the bagger issue.
12 horse should be plenty.
yzf450motoxrider
Thanks for the info. I was able find the manual, parts diagrams, and attachment brochure. It looks like the only thing it wont take is a rear plow. It will accept the clevis hitch. however not the plow. not sure why that is. As far as the blower it would be single I an a little worried it wont throw the snow far enough. Would a 4 ft plow be better?
boovuc
It won't accept the plow because the Eaton 700 tranny is a mid-duty transmission and plowing would ruin it. "Dirt" plowing is, IMO the biggest test of any tractor. Garden or farm.
Your fine with most other attachments except a 2-stage blower. Nice machine!
PS.......keep the 12 horse Kohler. It is a great motor with just the right balance of power and fuel economy.
Edited by boovuc
ScottCT
I use my 312-8 for clearing snow with the single stage blower. We've had storms here that have dropped feet of snow and that blower chews right through it launching it a good 15 feet in the air and 20/25 feet away so I don't see you having any problem with a single stage blower or horsepower. I also run the 37 inch deck on my 310-8. It's definitely not my favorite deck but I like using it with the bagger for leaves in the fall. I have the high lift blade on it and it makes a huge difference in the amount of suction the deck develops. The downfall of the high lift blade is (at least to the best of my knowledge) only available from Toro and it's about 110 bucks. Since I'm only using it as a giant lawn vacuum for leaves I can live with my old dull beat up blade but if you wanted to mow and bag your lawn you might have to bite the bullet for a good sharp high lift blade.
Tankman
​The 12 hp Kohler is a "forever" power house!
  • Similar Content
    • Evguy
      By Evguy
      IMG_6160.MOV I’m selling my B100 with 10hp Kohler engine and snowblower. The engine ran when I brought it home 3 years ago and deck ran smoothly. The 8sp gear box will need oil changed. I didn’t make headway and need the room for other projects.
      email or message me with questions
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
    • jebeli
      By jebeli
      Lets make a deal. The whole collection for $3000 or one tractor and half the items listed below for $1500.
      I am moving to town so am willing to do a partial trade for a wheelhorse more approproiate for a suburban lot- lawn ranger, surburban models, bcs walking tractor, other?
      I could possibly deliver or meet half-way or ship.
      Both tractors run great and are in good working order. Second owner of both machines. I work with these machines everyday so they are not perfect but are, in my opinion, in excellent shape.
      42in high-shoot snow blower
      42 in rear discharge deck
      Snow blade
      Front mount deck hanger with 42in side discharge deck
      30in lawn seeder
      Brinly single bottom plow with cleavis or sleeve hitch
      50in grader blade
      Extra transmission
      36in rear tiller - leaks a little
      Full set of tire chains for each tractor
      Various body pieces
      7.5 cubic ft pull behind cart - may need tires
      Extra set of rims
      All required belts, pullys, brackets, manuals, too much to list.
