Sparky-(Admin) 25,347 #51 Posted January 3, 2009 Mix sand in with the paint you use on your ramp to help with traction when the ramps covered with snow or just slippery from rain water. I guess nows a good time to make the door wider . Mike......... Share this post Link to post Share on other sites
KyBlue 655 #52 Posted January 3, 2009 Nah ill get a smalled blade in the future.. If I would have made the door wider, it would have messed with the whole Modular setup.. Thought about it, decided against it. Knew the blade fitting when angled was a long shot..ah well! Thanks for the idea on the sand!! Ill Give that a whirl when the weather stays warm enough to paint.. Share this post Link to post Share on other sites
kj4kicks 154 #53 Posted January 3, 2009 WoW! Looking nice Scott !If you can get enough swing radius, that blade may still fit. Angle it the other way and steer hard right as the front of the blade goes thru the door. Share this post Link to post Share on other sites
linen beige 16 #54 Posted January 3, 2009 WoW! Looking nice Scott !If you can get enough swing radius, that blade may still fit. Angle it the other way and steer hard right as the front of the blade goes thru the door. Share this post Link to post Share on other sites
KyBlue 655 #55 Posted January 3, 2009 Using E's suggestion (thanks I owe ya a ice Cream!) I managed to get the blade thru the door... But I gotta tell ya...What a PITA. I'll be on the lookout for a 42" sometime Soon. Figure I'll refurbish this one first.. Anyhow, The place looks Smaller when you get a tractor in there... Still gotta account for Stairs, a decent size snap on toolbox (dealer is holding my new one till work settles down) then it'll be a LARGE box... Plus I'll nee storage for Air Compressor, Welder, Torches, Plasma Cutter... you know the big boy toys... Its gonna fill up fast... Maybe I need to go Bigger!! Another 8 Feet maybe... Hmmmm Oh I got the Ramp Finished up too. Mitered the last 2x6 so it would not be such a hard edge. Good day considering that I worked from 3am till 1pm ... I'll get some pics Shortly! Share this post Link to post Share on other sites
HorseFixer 2,014 #57 Posted January 4, 2009 yeah 10-dash 4 on the bigger thing! ya never can go big enough! You think yers is looking small, mine will have 14-15 tractors in there along with impliments and parts and stuff All mine is for is storage sure would be nice to have one as a showroom but I just dont have that luxury Good job so far pal keep er going! Share this post Link to post Share on other sites
KyBlue 655 #58 Posted January 6, 2009 There always has to be somebody doesnt there?? I posted my build over on MTF thought maybe somebody else would use the whole modular idea.. anyway It'd been a pretty positive response and a good feeling to read them.. well there is always somebody who's gotta be a (sorry cant put the words im thinking) Heres what he was posted... just for your reading. For a shed it is over built. It is just in the wrong location. Too close to the other structure. Second you should have used T111 for siding. Your siding does not cover the end of the floor sheeting. You will end up with a lot of rot from water damage. It does not matter but the floor sheeting should have been staggered and the large door opening should have been sheeted from the middle out to give it strength. With that said it is very safe they way you built it. A 2x4 will hold 2200 pounds in compression. 1 stud will hold the truss and roofing up. A shed does not need a double plate on top. There is not enough weigh on on the top plate to matter. When building if the rafter does not fall over the stud you need a double plate to hold the load. The double plate is not only for strength but it helps keep the wall streight. Typical redneck shed. Just rap it with tar paper and you can call it finished. Share this post Link to post Share on other sites
Duff 206 #59 Posted January 6, 2009 Dang, Scott! Remind me to keep a whole lotta cyberspace between me and MTF! That's just plain rude! Hey, WE think you've done a good job, eh boys? Duff :hide: Share this post Link to post Share on other sites
KyBlue 655 #60 Posted January 6, 2009 Most everybody over there has had good stuff to say, and as much as I read over there... Ive not really seen that much negative rude BS over there... Ah well. Only takes one to ruin it.. Share this post Link to post Share on other sites
Butch 194 #61 Posted January 6, 2009 I just went over to MTF to see your thread. A Moderator must have removed his comment because it wasn't there. Share this post Link to post Share on other sites
KyBlue 655 #62 Posted January 6, 2009 They did. Got a few PMS from moderators over there actually. I asked them to delete his post, and all others related to it (cause a few others chimed in telling him what a Azz he was..) Share this post Link to post Share on other sites
KyBlue 655 #63 Posted March 24, 2009 Finally...a Update!! Haha Got the rafters up, need to trim the tails off thou, didnt notice how bad they stuck out before we put them up... Oh well, wont take alot just a lil bit with the saw.. long as I dont fall off we'll be good! Hhaha Share this post Link to post Share on other sites
bk-scouter 93 #64 Posted March 24, 2009 Looking good Scott ! I don't know if you had already mentioned it before and I missed the post, but to me it looks like your roof trusses are designed for storage space up there. If so, awesome idea! Keep up the good work... -BK Share this post Link to post Share on other sites
jusjeepn 59 #65 Posted March 24, 2009 It's been a long winter hasn't it Scott? I bet you glad to be able to get back to work on this and get it done! It's looking really good! Your loft should be able to hold a ton of spare parts. You might even have to cut a door in the end of the loft and install a transome so you can get the heavy parts up there too! Share this post Link to post Share on other sites
Duff 206 #66 Posted March 24, 2009 Looking good, Scott! Keep it up! Duff :omg: Share this post Link to post Share on other sites
Nick 13 #67 Posted March 25, 2009 The rafters give a whole new perspective to things, that has some size to it! Looks like you should have some storage space up there. Share this post Link to post Share on other sites
KyBlue 655 #68 Posted March 25, 2009 Thanks for the kind words all... Yep It's got a loft... and those Friggin Trusses (the gable end ones anyhow) weigh a TON!!! LoL Next will be the stairs for goin up.... fixin the Rafter tails... fun stuff!!!! Share this post Link to post Share on other sites
HorseFixer 2,014 #69 Posted March 25, 2009 Looks good pal! :omg: Share this post Link to post Share on other sites
d180man 5 #70 Posted March 25, 2009 Hi looks good to me ! nice job ! we hope to make one next month a 10x16 or 12x16 or 12x20 on 6x6 skids but goo work keep it up! :drool: Share this post Link to post Share on other sites
bustedglass 2 #71 Posted March 25, 2009 WOW . That is one HEAVY DUTY building. Great job, Great Horse Stable . Share this post Link to post Share on other sites
KyBlue 655 #72 Posted May 24, 2009 Its been awhile since I've done an update... well its been awhile since Ive had any time to put in on this... But I did manage to get a bit done here and there... Still have a bit more to do on the roof... But its getting closer. The top section is done and papered.. Still have the lower sections to do, need to trim up a bit more plywood to finish em off, then they can get papered too! Oh, the loft is done, and stairs are up as well - its not perfect... I probably should have used pre made trusses instead of building em, dont know if it was the sitting for months before putting em up, or sitting after they got put up, but they have twisted and moved on us... So nothing is perfect anymore... Oh well... Share this post Link to post Share on other sites
HorseFixer 2,014 #73 Posted May 24, 2009 Looks good! Geter Done! :omg: Share this post Link to post Share on other sites
