scott76
Belts for 314-8
scott76
Hey All - have been a viewer of the forum for a while, but running into my first need to post a question.  I have a Wheel Horse 314-8, Model 73402 and Ser. # 6900191.
My dad bought this thing new and I've inherited it.   Replaced the drive belt last year and the PTO belt just broke yesterday.  The deck belt (42" (I think) side discharge) also looks rough.
I want to replace both the PTO and Deck belts, but cannot find numbers for the belts anywhere.    Can someone help me out??
Thanks!
daveoman1966
engine to trans belt is # 7473. Presuming you have a 42 or 48 side disch deck, the deck PTO belt should be 102742 or new # is 94-2501. Spend the few extra bux and get OEM belts...you'll be glad you did.
oldlineman
I always have had better luck ( but don't think it is luck just better belts) with OEM wheelhorse belts   :twocents-02cents:
scott76
Thanks for the info.  I found the PTO belt on-line and will order that.  I still need to find the number for the belt right on the deck (the one on the spindles).  Any ideas?
gwest_ca
Mower deck parts list
Operator manual
Garry
MambaJack
I am in a similar situation, need to buy a deck belt for a 314-8, that used to be my dads.  Not sure what size the deck is though, and the serial number is not legible.  i measured the from the end of one blade on one side to the blade on the other side and it read 40.25 inches?  Any idea what belt to get?
Dave
daveoman1966
For deck size, measure to OUTSIDE width of the gauge wheels.  Yours seems like a 42" deck, but can't be sure from the 40.25 measure you did.  If it is a 42" deck, presuming it to be a side discharge, then the deck belt should be # 6738 at 86" long.  Between 25 and 30 bux on line new.
I have a good used one for much less.  for details, clik my direct email link here:
daveoman@windstream.net
  • Similar Content
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • wheelHorse 312-8
      By wheelHorse 312-8
      Looking for part number for spindle assembly for wheel horse deck 78292
      thank you
    • Bill D
      By Bill D
      Found these at Lowe's.  Same belts as TSC, just different packaging.  The 86" I got was on clearance and is not being stocked anymore.  They had sizes from 87" to 109" in 1/2".  Not a lot of 5/8" belts that would be useful for our tractors.
    • Ifixoldjunk
      By Ifixoldjunk
      I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
    • Tim Fenn
      By Tim Fenn
      I've just acquired a renovated C125 but unfortunately the drive belt got snagged with the mower deck belt (maybe because of incorrect fitment?). It looks like I'm on a steep learning curve! I've been trying to find out which belt to buy as a replacement. The belt I've just taken off is 94 inches but  according to the parts manual I need a Toro belt part number 94 2501 which is 103 inches? The mower deck is a 42in rear eject. It's funny that the Toro belt has 94 2501 as the part number but is 103 inches & I apparently need a 94in belt? Any ideas?
