Restoration of 1957 Bolens Model 20HD02 Tractor
By
MasterGil, in Restorations, Modifications, & Customizations
Similar Content
By Evguy
B100 8 speed and short chute snowblower for sale near Indianapolis Indiana.
good deck and tires, kohler engine runs.
transmission needs axle seals and bearing.
needs steering wheel also.
too many projects, not enough room.
By Natejc_98
I’m looking for the recommended process to restore old wheels from grinding to sanding to painting. Also what tools are preferred in the process?
By blu_stang
Hi All, It's time for me to sell the D-250 I've had for the last 8 years. It’s useable as is, or would be a great project bundle for further restoration.
I am selling a large package: the running tractor, a refurbished snowblower (48”), parts snowblower, mower deck (60”), tiller (40”), front plow blade (60”), Cat 0 3-Point Hitch with adjustable top link, WH 3-Point tool bar, wheel weights and tire chains. Also included is an extensive part collection, nearly a second tractor worth. I will include the original manuals, an original 1976 sales brochure, and repair manuals for the tractor and the engine. I made electronic copes of all of the above, and stored the paper copies to prevent further wear. This is one of the most complete D-250 tractor/attachment bundles I’ve seen.
Some highlights from the available parts: Frame rails, extra engine, water pump, extra transaxle, extra gears, including worm gears (stored in oil bath), Front wheel set, carburetor, carb rebuild kit, rebuildable original radiator, extra radiator overflow bottle, rebuilt alternator, new voltage regulator (I was planning to change over to an alternator setup from the generator), new in package Renault engine seals, new PTO seals, ignition maintenance parts. There are also many panels, frame pieces, cables, levers, tubes (lines) and hardware in the collection.
The tractor engine runs smooth. There are around 1050 original hours on it; It’s a 1976 edition. Everything works, except the dash lights and the rear lights (disconnected b/c of fender). I just haven't sorted out the wiring, but it is all there. Headlights are good and working, as are all of the gears and levers. The four tires are nearly new Carlisle Multi Trac, with nubs still on them. The rear tires have been filled (ballasted) with Rim Guard for extra traction. The hydraulic pump, front PTO clutch and brakes operate but could use a tune up. I’ve used it for mowing and snowblowing on hills, driveway and around my land. I don’t have an original WH seat. The snowblower was rebuilt a few years back, and assembled with all new hardware and bearings. The mower deck gearbox was professionally serviced recently, and has a new set of blades with only a half dozen mows. The rear fender needs a repair, but all pieces are available. The plow and tiller are due for restoration. The Points, Condenser and rotor have all been replaced and tuned in. The battery is good. I've rebuilt the carb, replaced the fuel pump and changed out the plugs within the last 30 hours. The replacement radiator is from a Kawasaki engine; it was installed with new hoses. There are also new custom hydraulic hoses and a new hydraulic lift cylinder.
Here's a video of me mowing, this past summer.
Transporting this haul in one trip will require a pickup truck and a large trailer.
By Merl
Newbie here and I have a 520-H that runs, but needs some TLC and some minor things fixed and/or adjusted. It comes with a like new tiller that I believe has only been used once and has paint still on the tines. I am the 2nd owner and I have personally never used the tiller. I am selling my previous home that I rent and where it has been stored. My current home's yard just isn't big enough to use a rider and I need to find a new home for it. I want to sell them together to simplify and I need them gone in the next 2 weeks. Please reach out with any questions and I'll do my best to answer. I am definitely not as knowledgeable as most of you on this forum, but figured somebody would like to fix it up, part it out and/or needs a tiller. Please email or text.
