dodge78
Not for $389
dodge78
I was looking at Menards webite for battery and saw this plow.
http://www.menards.com/main/outdoors/snow-ice-removal/universal-snowplow-for-lawn-tractors/p-1910812.htm
Nordic Riding Mower snowplow is made of lightweight high impact injected molded ABS Plastic. Our 3 position blade with its patented rounded edge gives you the unique ability to plow over grass, paver brick as well as the everyday driveway. Our side mounting brackets will fit many mowers as is and can be modified to most others easily enough. The plow is light enough to be raised and lowered with our hand strap provided. Simple and easy to use is our goal and our unique blade will allow you to tackle summer jobs as well.
Round blade edge?  Hand strap lift?
bmsgaffer
I think if you put the weight/power of a wheel horse behind that thing it wouldnt make it to the end of my (short) driveway... :dunno:
608KEB
I wonder how long the rear end will last pushing a plow with that toy lawnmower!
craigbic
Yeah, pretty sure a Wheel Horse would kill that thing. Did you see the strap mounted car/truck/suv version they have? http://www.menards.com/main/p-2384723.htm I'm betting the first time you hit a raised bit of pavement or a curb stone with that, you're going to bust the "plow" and punch a hole in your car.  :snooty:
bmsgaffer
It looks like it gets strapped to the HOOD! You could do some incredible damage to a car that way... Many cars have aluminum hoods (like the buick they show there) costs nearly $1000!
I would not be strapping a plow to my $1000 aluminum hood...
gregg'shorses
Those cheap transmission in the new machines will be cooked.
Don1977
They didn't show any videos of those snow plows pushing snow. Using the words of Jase Robertson, "There must be a reason".
  • Similar Content
    • David414
      By David414
      I don't have any prior knowledge or experience with this plow as I will be a first-time user. Need some help please.
      I brought this well used plow, which I believe is a Brinly PP-500 series as the exploded part view seems to match up with my plow.
      Completely disassembled the plow, removed all rust, primed, painted, (wheel horse red of course) and re-assembled with new fasteners.
      Having trouble with the coulter blade, as it doesn't seem to fit this plow? Please refer to the pictures below.
      It appears to mount only one way, but it seems too big for this plow.  Do I have the right size coulter blade?
      What am I am doing wrong? Also is the front yoke assembly mounted correctly?
      Thanks
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • Bbo44
      By Bbo44
      SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
      52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
      48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
      48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
      MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
