Countdown To Christmas!
Similar Content
By the jeep driver
My daughter was using the Wheel Horse rider to mow, I was push mowing. She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving. I disengage the blades, and re-engage... nothing. No movement from the belt nor clutch. Then I notice the smell, and look closer, the belt is so hot is melting on the clutch. Or rather, the clutch is so hot it's melting the belt. Melting occurred.
While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
So, what did I do now? Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall. I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad. I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
Some pictures of the clutch, can anyone tell if it's usable from them?
By the jeep driver
I have a 1985 Wheel Horse 417A 31-17KE01. When I pull up the lever to disengage the drive, the belt will continue to move erratically (slow, speed up, repeat.) I've attached a couple of pictures, and have a one minute video showing how it's operating... (this is a OneDrive link, if it's not working someone please let me know.) I wish I could provide more info in my post, but I don't know enough about what's occurring here to do so.
https://1drv.ms/v/s!AsmNVhojMf_GqAHdTKh3d5-0uFVI?e=30SyhH
By the jeep driver
Hello. I have a 1985 Wheel Horse 417A 31-17KE01. A hydraulic line has blown, and I need help identifying the transmission or more specifically the hos part number. The part diagrams I found online are not listing a hose part number, or the diagram links are dead. Here is the best one I've found, but again, no hose part number.
https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/toro/riding-products/1985/31-17ke01-417-a-garden-tractor-1985/automatic-transmission-400-series
I think the transmission is the 400 Series, basing this guess on the lack of an oil filter in the 300 Series diagram.
I've taken some pictures.... rear of the tractor, circles indicate where the hose was attached.
At the front, under the battery tray.
The hose; if I stretch it out, it measures 27" (if the fitting was still attached.)
Thanks in advance for the help!
By Jsig
Hey new guy here. I just bought a 417a with an eaton 1100. The motion control would work in disengage and engage mode. Just changed the drive belt and now it only moves in engage mode. Can anyone tell me which is correct?
Thanks
