Tyler9014
What exactly is this tiller?
Tyler9014
I just picked this tiller up and it seems to have the wrong engine on it compared to any other pictures I can find. The engine is mounted to a thick aluminum plate which is then mounted to the frame. The way the engine plate is mounted seems professional, possibly original. Engine is a cast iron Techumseh/Lauson 8HP. Any information on what I have here would be greatly appreciated.
Tyler9014
Just realized I posted this in the wrong forum section, not sure how to move it to the attachments forum
gwest_ca
A-32244 is a 1963 serial number so should be a model WT-242 tiller.
Garry
stevasaurus
Don't worry...the Mods will move it if they want.  It looks very close to this image I found in the gallery...at any rate...you can bet it is a WT-24?  The T is for tiller, 24 is 24" and the last number is the year...in my link...it is a 1962.  :)
Tyler9014
Thanks,mine obviously has the wrong engine and gas tank set up. From what I can tell they are kind of hard to find so i had to get it.
stevasaurus
Absolutely, got to grab it.  Jason, I hope, will find his way in here, (casual observer)...I think he will have some thing to say here.  He is into this stuff.  :)
Edited by stevasaurus
CasualObserver
That tiller is, as has already been identified, a WT-242.  Lots of posts in the past, if you search for any of the models WT-241 WT-242 or WT-244 in the search box you'll find several threads.
The WT-241/242 models used a Lauson V55D engine and had the smaller tines, the WT-244 model used a Tecumseh V60 and had the more traditional tines that continued into the tractor mounted models.  The original style fuel tank engine shroud is difficult to find but not impossible if you want to restore it to the original look. The same setup can be found on the Reo Lawn Skiff models, as well as the early Cub Cadet 60, although I don't know what engine models/specs were on those machines, and I don't have any documentation handy to look. The only difference I've seen in them is that some of the fuel fill spots were centered and some were off-centered. Truthfully if you could find the right tank setup and a good V60 or V70 block, very few people would know the difference.
These WT-24x tillers were a Wheel Horse design, even submitted for a patent in 1961. Ironically though, by the time the patent was issued in 1965, they had already dropped the product line and moved on to a tractor mounted and belt driven unit.
The patent can be viewed here in Google's Patent search---->http://www.google.com/patents/US3193022
or if you'd like to download a copy, it's in the manuals section here---->
Here's a copy of the spec sheet if that's of interest for display at a show.
WT242spec.pdf
I had a WT-244 for several years. It was a low priority project that has moved on to another collector. I enjoyed the conversations it stirred up at shows when I'd take it for display. It's a unique piece and generally gets noticed if you display it. On these tillers, the lift bar goes into the slot hitch, and the tiller pivots on the rear wheels to drop into and be lifted out of the ground. I've never seen anyone actually use one of these although my original goal was to try. If you think you want to try, the tractor pulling the tiller should be fitted with an SR-62 or SR-64 speed reduction kit (which are damn hard to find) or use it with a six-speed tractor. The standard three speed uni-drive is too fast for a tiller.
Glad you were able to get it, thanks for sharing. I hope you enjoy it. :thumbs:
Tyler9014
Thanks for all the info. I will probably just get it running and show it as is behind my suburban 400 that Stevasaurus and others helped me to get back into usable condition. I am always amazed at all the helpful members on this site and the amount of knowledge you all are willing to share.
Geno
Very nice piece Tyler, glad you got it.  :handgestures-thumbsup:
  • Similar Content
    • Bill Winn
      By Bill Winn
      For sale. 1981 WH C-175 Kohler twin series 1
      1. Tractor has brand new ag tires all the way around, brand new seat, new points and condenser, new rear blade quick attach bracket, lights have been rewired with LEDs, it has a brand new lift cable and bracket,seat pan is from a 410... it's surface rusted but at least it isn't busted up like the oem plastic one, starts and runs but smokes a bit on startup if it's been sitting for months but she runs smooth and strong.
      2. Tiller is like new. It had been used only about once when I bought it and now it has been used 4 times more. Tines still have much of the factory paint on them.
      3. 42" mower deck works perfectly, 4. snow blade was/ is rough but I repaired it so it is quite functional,
      4. Brand new rear grader blade,
      5. Wheel Horse brand plow,
      6. Wheel Horse brand disc- I added a piece of motorgrader blade for a drag. I also welded a post to the top to hold weights,
      7. Wheel Horse brand cultivator,
      8. Home built furrower. (Makes good rows)
      The original Wheel Horse plow/disc/cultivator originally came as a modular kit and in order to use it the draw bar and clevis hitch had to be swapped back and forth. (big pain) I fabricated draw bars and hitches onto each piece so this is no longer necessary.
      I think this is a fair asking price at $2200 for all.
    • oliver2-44
      By oliver2-44
      Anyone have any Troy Bilt  Pony Tiller Gear Box Experience?
      So about a year ago an older neighbor gave me this Troy Bilt Pony Rear Tine tiller.  Said he forgot he drained the engine oil and started it.  Bore diameter was actually good, but has a bunch of large vertical scars on cylinder walls.
      Fast forward, my wife has volunteered us to help a Youth Summer Camp that runs an  "Outdoor School" during the 9mth  school year.  They had a fairly large garden for several years, but it has been neglected & overgrown for a couple of years.  So she drives past this neglected garden daily!
      There's some scheme emerging where we have half the garden to ourselves and help with the other half where students will plant and weed and pick their produce.  I enjoy a garden, but not real keen on some of the aspects on this one...( a bunch of 6" high raised beds with paths to narrow for my big feet to turn sideways. But I've already been committed, O I mean volunteered.
      So engine is shot (aluminum block)  but I have a Predator or a K181 I could put on it.
      The wheel shaft seals looked shot and had a bunch of play so brass wheel bushings were shot. (the other 2 shafts have tapered roller bearings).
      No model number, but from the "Pxxxxx" serial number and Briggs engine I've dated it to a 1981.
      MTD now owns Troy Bilt and their "on-line manuals" go back to 2000.  Called their Tech Supports and got "Deer in the Headlite" comments regarding a 1981 Service Manual.
      Searched online and founds lots more info on the larger "Horse" model, and a 1991  Pony service manual.
      While they basically look the same, there's been several generations of re-engineering the internals to simplify manufacturing and eliminate castings it appears.
      I found this parts diagram to be the close's match to what I have.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/wheel-tiller-shaft-assemblies-7/
      I disassembled it and I think I marked everything as to what faced the front, back or R,L side.  Internals looked OK, but the wheel shaft seal area is not the greatest.
      Most parts are NLA but found bearing. seals & bushings on ebay. $130
      Reassembled everything and used the 1991 Service Manual as a "Guide" to shimming the 3 shafts end play.
      Everything turn freely in both directions when in neutral. But when I engage the Wheel Shaft "Clutch" it binds up. The clutch lets the wheels roll freely or engages them to power.  It uses belt idlers to reverse direction from a second shaft on the briggs (like a walk behind snow blower drive)
      photo from phone here
      This internal clutch actually works by using a pawl disc which is keyed to the shaft to engage the wheel
      shaft gear which is free wheeling on the shaft.
      I've loosened the bolt on the bearing end caps slightly and no change.
      This uses worm gears and I know "some" worm gears are designed where they must be "power driven"  in each direction (My boat lift is like this)
      So the rear tine gear shaft turn freely in each direction.
      The wheel shaft locks up when the clutch is engaged amd trying to turn it in what would be the forward direction.  But it will turn freely with the clutch engaged if going in the backwards direction.
      The wheel shaft gear cannot be turned backwards because of the clutch mechanism on the one side.
      The rear tine shaft bevel gear turn freely in both direction in neutral but is bound up when the clutch on the wheel shaft is engaged.??
      There is a Main Drive Shaft that has the Worm Gears on it to drive the Wheel Gear and a second worm to drive the Tines Gear.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/main-drive-shaft-gear-assemblies-4/
      This shaft is made up of a smooth shaft with the worms keyed to it and spacers in between them.  I disassembled it (and carefully laid out each piece in order) to wire brush everything clean on the grinder as there was some rust from water in the very bottom of the gearbox.
      I find it hard to believe that I could have one of the worms backwards because it seems it would not turn freely when the wheel clutch is not engaged??
      To remove it I have to disassemble everything and might ruin my seals as I have to drive them out. (dumb me, I tested everything to turn freely before I installed the seals, BUT I didn't engage the clutch)
      Just a note,, I didn't try to turn everything with the "clutch engaged" "Before" I disassembled it so I don't know how hard it should turn, but it had to turn via a belt drive verse's now totally locking up.
      Regrettable a nonworking tiller doesn't get me out being volunteered.
      Did I say I actually enjoy a garden!
      Thanks for any suggestions and listening to my rant.
      This is the input shaft from belt pulley
      Special woodruff key
      Tiller Tine Shaft
      Some one was in here before me. These are threaded holes with removable set screws to drive the bearing cone out. No set screws just filled with caulk or body putty.
    • wh315-8
      By wh315-8
      Anyone be able to measure out the Top Link Bar for the 50” D Series Tiller?
      Just finished rebuilding a tiller, have a adjustable type but would like to put a original type on like the manual has listed.
    • wh315-8
      By wh315-8
      My 50” D-series tiller input shaft has like 3/16” +\-, play pulling in or out. Anyone else have this same thing. Is it supposed to have that much play? Have it all apart and was thinking of adding a shim or 2nd thrust bearing to lessen the play to at least 1/16”.
    • Joe Warren
      By Joe Warren
      Bolens FMC 33" Rear Mounted Rotary Tiller, New Old Stock, Model number 18093 02. Includes tiller, drive shaft, mounting brackets and hardware.
      Fits Bolens large frame lawn and garden tractors.  Drive shaft length changes with tractor model. Contact me for further information.
      Price reduced to $449. Local pickup in Easton MA. Or, I may be able to deliver to southern New England, Eastern  NY, or Bridgewater NJ area. Message me with any questions.
      Thank you,
      Joe
