caddisman
Wheel Horse 48" Mower Drive belt
caddisman
I have wheel horse side discharge mower deck and unsure what belt to use for the drive belt. The mower is on a 14hp 8 speed Automatic from the mid 70's. The belt look to be around 3/8 wide and 96 inches in length. I cant read the original numbers. Can anyone help?  Thanks, Anthony
gwest_ca
The model 5-1210 deck uses a 102742 drive belt that is 1/2" x 103".
Spindle belt is 1594 which is 1/2" x 107.21"
Decks are sized by their width of cut - not the width of the deck.
Tell us more.
Garry
caddisman
Thanks Garry. My mower would be the 5-1010. Thanks for tip on the size of the mower. It would the 42 inch model. Do you know what the correct belt for the 42 inch deck.?
Thanks,
Anthony
gwest_ca
The 5-1010 uses the same 102742 drive belt that is 1/2" x 103" as the 48" deck.
The spindle belt is 6738 which is 1/2" x 86".
Make sure you get a belt that is designed to bend backwards over a flat idler.
If you ever get stuck search the Manuals here using the word chart.
There are not that many to pick through to get the one you want. The belt dimensions are on the last pages of each belt file.
Garry
caddisman
Thank you Garry for your help. I have from now till spring to find the belt. Should have no problem with that.
Take care,
Anthony
Josey Wales
How about the blade numbers :) And where can I get a set? 48" deck. Assuming that belt info is the same?
gwest_ca
Do you know the model number and serial number of your deck? Here is a list of the decks. Belt numbers may be the same but I like to check against the model number to make sure.
Mower DNA
1966-1967 model RL-486 replaced by
1968 model 5-1481
1969 model 5-1482
1970 model 5-1483
1971 model 5-1200
1972 model 5-1201
1973 model 5-1202
1973-1974 model 5-1210
1975 model 5-1211
1976 model 65-48MS01
1976 model 65-48MS02
1977 model 75-48MS01 - These all used blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded.
Note - 3/4" or .750" is 19.05mm
1977 model 75-48MS02 - Uses 6203 bearings with 3/4" ID - (First deck to use blades with 3/4" center hole)
1978 model 85-48MS01 - Uses 6203 bearings with 3/4" ID
1979 model 95-48MS00 - Uses 6203 bearings with 3/4" ID
1979 model 95-48MS01 - Uses 6203 bearings with 3/4" ID
1980 model 05-48MS01 - Uses 6203 bearings with 3/4" ID
1981-1983 model 05-48MS02 - Uses 6203 bearings with 3/4" ID
1984 model 05-48MS03 - Uses 6203 bearings with 3/4" ID
Note - 17mm is .669"
1985 model 05-48MS04 - Uses 6203 bearings with 17mm ID
1986-1988 model 05-48MS05 - Uses 6203 bearings with 17mm ID
1987-1988 model 05-48SC01 - Uses 6203 bearings with 17mm ID
1989 model 15-48SC01 - Uses 6203 bearings with 17mm ID
1990 model 15-48SC02 - Uses 6203 bearings with 17mm ID
1991-1992 model 15-48SC03 - Uses 6203 bearings with 17mm ID
1993-1997 model 78360 - Uses 6203 bearings with 17mm ID
1998-2007 and 2009-12 model 78361 - Uses 6203 bearings with 17mm ID - These all use blades with 3/4" center hole
Garry
gwest_ca
Should have included -
If you know the model number of your deck find the ipl (illustrated parts list) in our library. The file description page should have the belts listed and the blade part numbers on it. Saves you having to download anything to see them.
Here is an example.
Clicking on the picture will take you to the file description page where this info is posted.
Clicking on Download will take you directly to the file.
Garry
  • Similar Content
    • CS-17
      By CS-17
      Sold!!!
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
