Similar Content
By Steiner430!
Will a c series transaxle fit in a b series? The dip stick tube looks to tall to fit under the fender. What modifications does it take to make this work?
By WHnoob
I finally got a couple hours of shop time to try to assemble one working tractor from the C-160 (broken tranny) and B-80 (broken engine), both 1974's. The short-term goal is to move the 4-speed from the B-80 into the C-160 in time to use it for snow-blowing this winter. Then over the winter I can work on rebuilding both the 8-speed from the C-160 and the K181 on the B-80. So I got both transmissions detached from their respective tractors and it looks like everything should bolt right up - even the input pulleys are the same size!. However I encountered two problems with the 4-speed so far:
1. The right hub is turning on the axle, so something is obviously wrong with the key/keyway. I don't currently have a hub puller to see what's up.
2. The left wheel is stuck/rusted to its hub. I tried some PB blaster and pounding a cold chisel into the gaps between the wheel and hub but it didn't budge. I wanted to just switch the wheels, since the C-160 has larger diameter tires (though the wheels are the same size), and the B-80's tires aren't looking so great. But maybe the C-160 will just have to have a low rear end for the winter.
By IH8RDS
Hi! New member here. My Name is Scott and I live in Sweetwater Tennessee. Retired Air Force and now enjoying the retired life. Im the owner of a 1976 B-80 for about 4 years and I have the 36" tiller and yesterday purchased the push blade anticipating some snow this year. I use the 36" rear discharge deck regularly to cut about 3 of my 7 acres with the Wheel Horse. I think I need a bigger deck! The tiller gets plenty of use as I do gardening and can all of my vegetables in the summer.
Looking forward to gathering and sharing info on here. Thanks for having me.
Scott
By Ty Fritz
Please forgive the question, if it's been asked and answered. I'm new to the site, and had trouble searching for an answer to my issues
I use my Wheel Horse B-80 all year round. It started acting up a couple of weeks ago, first it would die while mowing. I could restart it easily and finish the job. A week ago it wouldn't start and had to use a battery charger because battery needed help. It would run until it warmed up and die like you turned it off. This is not normal for this unit, usually it starts right up, not continuously cranking. At that time I was thinking it was fuel delivery, so I bought a carb re-build kit (gaskets and needle valve), blew out the carb, put it back together. Same thing, 10 minutes and done, won't restart. Bought a new fuel pump, fuel lines, fuel filter, air filter and cleaned the tank and screen on the pet cock. No change. This weekend bought new points, condenser, plug and replaced the now toasted battery. I was able to mow for 30 minutes then it died and wouldn't start. Checked for spark again, nothing. Replaced the coil and was able to finish the days toils, however it did die twice while using it and start right back up. When it dies, it's a complete loss of power. You would think it's fixed, but no. Still dies after warming up. Besides the part listed above that were recently replace, I've also replaced the rectifier, ignition switch and starter solenoid two years ago. Any and all suggestions are welcome at this point, tired of throwing parts at it. I need it ready for Indiana snow.
Thank you in advance,
Ty Fritz
