BadDad
1100 special
BadDad
Model # 01-11B803 year 1980  eng. ID 52417-0198-01-79031511.
Ok I have said all that too ask a question. The tractor is in very good shape I am the 2nd owner. I have notice that when I am going down a little grade that the transmission goes into free movement then it will pick up and pull on its own. it does this while mowing in the yard, it is like it goes into neutral for just a little bit. Can some one tell me what is going on?
dcrage
Many of us have experienced this phenomena. Haven't read a good explanation for it yet. The general concensus is that an after market foot control takes care of a lot of this issue.
MalMac
Be it right or wrong, that is very normal for the Eaton 1100. Best way I handle it is to anticipate it and act accordingly with a simple pull back on the motion control lever if the situation requires it.
gwest_ca
This is a 6-speed with 1" axles but all seem to have this condition. I think what happens is you are going from acceleration to deacceleration  and the slack in the gears between the ground and the engine through the 100-to-1 or whatever it is gearing takes a few seconds to catch up.
Garry
Sparky
Could the hub be loose and its spinning on the axle some?
Just a wild guess of course.
Mike..........
MalMac
Well I did not check the tractor model number. Since it's a manual I guess I am out in left field with that answer.
ol550
 Would suspect a weak clutch spring.  Try slipping your toe under the clutch pedal
when going downhill to see if it helps. :dunno:  Could also be a worn or over length
belt.  :confusion-confused:
Racinbob
I'm inclined to agree with Garry. Everything from the wheels to the input shaft have to switch from go to whoa and it takes a bit. Possible a bit more if there's more wear on everything.
BadDad
Thx every one for the info.
stevasaurus
Right, you have a #5086 4 pinion with 1" axles.  This is common on almost all tractors.  Like ol550 said, you might fix some of it with a new clutch spring.  I believe it is just the slack that happens in the tension pulley...for sure it is not in the transmission...no way it is in there.  :)  It is either the clutch spring or the belt...I am not sure you can get rid of it...it is how the system works.  Check the belt, clean the pulleys (wipe with mineral spirits) and maybe replace the spring.  If you can fix it at all, this is where it is at.
dcrage
"Well I did not check the tractor model number. Since it's a manual I guess I am out in left field with that answer."
Me too. Saw the '1100' in the title and I just 'assumed' the topic was about hydros.
  • Similar Content
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
