Swemill
Work with the D-180 (pics)
Swemill
Thought I should share some pics of work with the D-180.
My father needed a new layer with gravel stones on his yard and took the Horse to the local quarry.
This is located about 7,5km away and gives a trip about 15km / 9 miles each turn. He drove 5 turns with no problem…. =)
The first turn he took a little too much load and nearly got stuck in the hill with spinning tires… He had about 1350kg / 3000 pounds on the wagon. The other turns he got about 500 pounds less.
With the biggest load this carriage weight was about 2800kg / 6200 pounds. Fairly heavy and it went very fast downhill’s…. The hydro couldn’t slow the speed down (from full hydro) because of the weight and mechanic brakes would be nice to have… With not full speed on the hydro before the downhill it worked better and it could hold the force.
Pollack Pete
Hi.Nice D-180.Good to see a big horse getting a good work-out.How many miles per gallon did you get.Ha,ha.
Brrly1
Good to see everyone out having a great day. Tractor and trailer look real good, nice setup.
JERSEYHAWG /  Glenn
A beast of a worker. Thanks for sharing that with those good pics.
Glenn
Glenn
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
