JPeoples
NEED CARB HELP!!! on a 655 Wheel Horse
JPeoples
I have a 655 Wheel Horse with a Tecumseh engine and it had sat for a couple years before I bought it. My buddy said he could clean and rebuild the carb for me. Well when he did it he didn't adjust it right and now I cant get it adjusted right either. I will run fine if I keep spraying gas into the carb but it can't run on its own. I was wondering if anyone could tell me how to adjust the carburetor or give me a good reference to figure it out.
slammer302
If its acting like its not getting enough fuel like having to hold the choke on or spraying fuel in it to keep it running you need more fuel so unscrew the screw on the bottom of the bowel in small adjustments till it runs on its own and make sure the fuel is getting to the carb
JPeoples
It does act like its not getting enough fuel and I have done that, but once I get it to were it can run with the screw at the bottom of the bowl when I try to turn the deck on it stalls out and i think it is because I don't have the other screw adjusted right either
km3h
If you get the engine running smoothly and engaging the deck causes it to stall you might be having problems with a safety switch. Not familiar with that tractor but just a thought.
JPeoples
Thanks Mikez655 that does help a lot I appreciate it!!! :thanks:
  • Similar Content
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
