Grandad's Sk-486 needs help.
By
Kwa1ski, in Wheel Horse Tractors
Similar Content
By JoeM
Good Toro XI Lift Valve and Cylinder Assy.
Hurry this deal won't last! $60 Plus shipping.
By CS-17
Sold!!!
Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
I received it in non working order, I have since done the following repairs: To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter. To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted). This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer. Please feel free to CALL me for details or any question! THANKS for looking! -
By rustyedge1
Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
All help appreciated..Have PayPal or can send check..
By WheelPuke
I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
By D_Mac
Going to possibly pick up a bolens 1256 that's been sitting outside for sometime. My question to any of you who have had one or knows about them is how to get them to free wheel. I would need to push it from a field to a driveway. From what I have read there is a pin on the right hand side, on the hub of the rear wheel that you pull out to get the wheel to free spin. Is there any other tow or dump valve on these machines? Also any thoughts on this model in general. Never had one before. Also never have had a wisconsin engine either. What should I expect?
