chevyaddict83
Ark 508 loader, more questions
chevyaddict83
So, i ended up rebuilding curl pistons, worked great. Now, having lift issues. If i pull on the lift lever slightly, i still get the arms to go up. If i pull all the way back, the whole thing drops. If i leave it raised and fill the bucket, it stays up and dumps fine. Is it something in the control valve? Maybe an adjustment?
Sent from my LG-LS980 using Tapatalk
Madcat
Sounds like the control valve is going into the float position when you pull it back. Maybe you got the valve reversed or the hoses reversed.
chevyaddict83
I didnt think i had a float position. It was working like it should, then it started happening
boovuc
If you have the original Ark manufacturing control valve(s), you have a float on it. It does sound like the valve/lines in & out are reversed.
This is what the original control valve looks like.
MalMac
I agree with what was said about lines reversed. Wow that would be dangerous having the arms just drop. When you pull the control lever all the way back, do you feel it snap or clunk on the very last of the travel stroke of the lever. If so your going into float.
chevyaddict83
Now, my first question is, if the lines are reversed, wouldn't the up down function be going backwards? Or just pressure in the opposite direction, like more dwonforce instead of up? It was working good, then it got fussy
boovuc
It may not be just that simple but if you have the original control valve the Ark came with, it has the float feature when pushed full forward. If you didn't change the valve in any way or the inlet/outlets it may be nothing more than air in the lines. After you rebuilt the cylinders and added oil, it is recommended to slowly raise and slowly lower the arms then do like wise to the bucket doing full motion slowly. Do this several times to both systems and check your oil reservoir adding if/when needed. (Make sure your oil isn't full of micro bubbles after using it a while).
If your certain you have all the air out of the lines and you don't have the reservoir overfilled, I concede to the hydro gurus for more possible explanations short of debris hanging up in the system.
brandonozz
I have a Ark that is doing something similar but not when I pull the lift lever all the way back.  My loader drops slightly when I pull the lift lever ever so slightly.  An axample would be when a load is lifted half way off the ground and held there.  Then raise the load higher.  If I pull the handle 1/16" the load will actually slowly drop.  If I continue to pull the handle a bit further the fluid flow will "catch" and the load will raise and act as it should.
My guess in both your case and mine is spool valve wear.  Hopefully someone who has taken one apart can chime in as to their thoughts.
shorts
It's the nature of the beast for this hydraulic system to drop a bit when the load lever is moved after being in the center position.  these hydraulic systems use a fixed displacement pump that bypasses or builds no pressure until it is diverted thru the valve to do work, consequently you get a little drop when you try to lift a load.  The newer no drift systems use a constant pressure variable displacement pump along with usually pilot operated valves, so their is always pressure on the system in the valves even when they are in the neutral position so that when you move the valve the hydraulics don't have to wait to sense the need for pressure to lift the load.
pfrederi
What Shorts said....I had noticed th same issue with my D200 and her ARC loader.  Went to the hydro repair place and he told me it was normal. Just move it a bit faster he said
chevyaddict83
I lnow the drop you guys are talking about. Mines different. Ill try and post a video
brandonozz
Didn't think about the lack of pressure in the system causing a little "slack" when the handle is first pulled.  Makes sense now.
Thanks for the insight!
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • edwroy
      By edwroy
      Needs some help. Purchased an ARK Loader - Model 550 Serial # 573 - anyone know what year this might be?
      Thanks,
      Edwroy
    • boovuc
      By boovuc
      Well the Grange Fair was a short visit!
      Started uninterrupted work on the loader at about 1:30 this afternoon. Finished at 8:20! It was worth it. After some cutting, grinding, filing and minimal cursing because I had no time constraints, I got it on. Thanks to my Karen who slid the tractor under the mount while I held the frame up. (Never made the stands. Used the brace arms to get it off the blocks). No leaks, no seeps, no noises, and full function of everything. Pump is very quiet and barely moves the vacuum gauge on the tractor. Much less work for the motor than my 48 inch mower deck.
      I didn't put the rear weight on so I took it easy and made sure everything was primed in the lines. Plenty of down pressure and fast movement. A big thank you to Malmac, Scott, Wallfish and the others who offered advice and posted pics of their loaders. The biggest pains in putting this on a 520 since it wasn't factory designed for any of the Onan powered tractors was the pump mount and the lever release/lock Attach a matic that is used on the newer tractors and the 1991 520-H. (My 1992 416-8 didn't have the lever design).
      It required cutting out a long skinny triangle from the thick metal original sub frame to allow alignment of the frame holes and shortening the actual lever. (The frame cut took three cutting disks and a good portion of a fourth). I also had some issues with the nut/bolt used on the front mounting bracket. The first frame hole on each side has VERY little room to start a nut. (Because of the gear reduction steering assembly). On the positive end, the factory brace arms leave plenty of clearance around the Onan and hood. My suction line to the pump will need moved since it is in harms way. I think the pump is OK where it is at with a guard to be made soon. I'll work it harder on Monday and really heat the oil up and check again for leaks or seeps again. I do have to weld a wallowed loader lift cylinder pin hole but even it isn't too bad. The others are real tight. Not bad for as old as it is and for 500 bucks.
      This was always a real want for me so please excuse my over exuberance. This makes the beginning of the work week a joy! It might take until noon at work tomorrow to wipe this grin off my face!
    • prondzy
      By prondzy
      So i have an ark 508 loader on my c160. I was wondering if any of the other Ark FEL owners could tell me if there is a "float" postion in the spool valve?
    • bo dawg
      By bo dawg
      Is it hard to pull apart to replace seals? Any tricks? Or things to watch for?
