edwroy
ARK Loader
edwroy
Needs some help. Purchased an ARK Loader - Model 550 Serial # 573 - anyone know what year this might be?
Thanks,
Edwroy
boovuc
If your ARK loader was meant for a Wheelhorse, it would have a Wheelhorse number somewhere on the frame. (normally near the top of the right hand column on the drivers side).
The 550 was given the WH part number 97-48FL01. These were meant for the D series horses though a few members here have mounted theirs to the C series or the 300, 400 & 500 series.
ARK supplied that 97-48FL01 part number from roughly 1976 to 1982.
If your 550 loader wasn't made specifically for WH..........it would be difficult to nail down when it actually was made.
edwroy
Thanks for your response. I did not know. It may explain the orange paint under the red.
Thanks again,
Edwroy
Dieselcowboy
My 550 ark is orange also. It was bought new on a D200 in the 70's. I got the owners manual with it and sales receipt., has a wh right on the cover.
boovuc
Interesting although they may have been repainted over the years or the paint aged over the years. (Maybe ARK used orange paint from the start). The ARK I bought when I stripped it was all WH red and very difficult to get off. It did have a little  paint on the cross beam where the WH logo was but it was either Regal Red or another close rattle can paint. Everything else was the original paint. Mine had to have been garaged over it's life considering the PM wasn't meticulous about his possessions. (The 312 it was on when ramairformula74 found it for me was painted 'Mother-Nature Oxidized Brown").
Goes to show that just keeping them dry and out of the weather means a lot! Regardless for dating purposes, the 550 ARK fits the bigger D series so if it was made specifically for the WH, it would fall close to those years of manufacture.
  • Similar Content
    • boovuc
      By boovuc
      Well the Grange Fair was a short visit!
      Started uninterrupted work on the loader at about 1:30 this afternoon. Finished at 8:20! It was worth it. After some cutting, grinding, filing and minimal cursing because I had no time constraints, I got it on. Thanks to my Karen who slid the tractor under the mount while I held the frame up. (Never made the stands. Used the brace arms to get it off the blocks). No leaks, no seeps, no noises, and full function of everything. Pump is very quiet and barely moves the vacuum gauge on the tractor. Much less work for the motor than my 48 inch mower deck.
      I didn't put the rear weight on so I took it easy and made sure everything was primed in the lines. Plenty of down pressure and fast movement. A big thank you to Malmac, Scott, Wallfish and the others who offered advice and posted pics of their loaders. The biggest pains in putting this on a 520 since it wasn't factory designed for any of the Onan powered tractors was the pump mount and the lever release/lock Attach a matic that is used on the newer tractors and the 1991 520-H. (My 1992 416-8 didn't have the lever design).
      It required cutting out a long skinny triangle from the thick metal original sub frame to allow alignment of the frame holes and shortening the actual lever. (The frame cut took three cutting disks and a good portion of a fourth). I also had some issues with the nut/bolt used on the front mounting bracket. The first frame hole on each side has VERY little room to start a nut. (Because of the gear reduction steering assembly). On the positive end, the factory brace arms leave plenty of clearance around the Onan and hood. My suction line to the pump will need moved since it is in harms way. I think the pump is OK where it is at with a guard to be made soon. I'll work it harder on Monday and really heat the oil up and check again for leaks or seeps again. I do have to weld a wallowed loader lift cylinder pin hole but even it isn't too bad. The others are real tight. Not bad for as old as it is and for 500 bucks.
      This was always a real want for me so please excuse my over exuberance. This makes the beginning of the work week a joy! It might take until noon at work tomorrow to wipe this grin off my face!
    • chevyaddict83
      By chevyaddict83
      So, i ended up rebuilding curl pistons, worked great. Now, having lift issues. If i pull on the lift lever slightly, i still get the arms to go up. If i pull all the way back, the whole thing drops. If i leave it raised and fill the bucket, it stays up and dumps fine. Is it something in the control valve? Maybe an adjustment?
      Sent from my LG-LS980 using Tapatalk
    • prondzy
      By prondzy
      So i have an ark 508 loader on my c160. I was wondering if any of the other Ark FEL owners could tell me if there is a "float" postion in the spool valve?
    • bo dawg
      By bo dawg
      Is it hard to pull apart to replace seals? Any tricks? Or things to watch for?
    • JackC
      By JackC
      I acquired an ARK 550 loader for my D-200. After I got it installed and tried to use it, the bucket cylinders would not hold the bucket in position with weight in the bucket.  It appears that the cylinders need to be be rebuilt. I can move the cylinders and bucket up or down by pushing one way or the other. I assume the control valve is OK but don't know.
      I checked with a shop that does hydraulic repairs and it sounds like it would be about $100 per cylinder to rebuild them and two weeks because the shop is very busy.
      Does anyone have experience rebuilding these cylinders, have a link to a repair manual and know the parts and tool needed?
      Thanks,
      Jack.
