Bowmard
Tapered Roller Bearing Conversion For Wheel Horse Tractors?
Bowmard
In addition to Wheel Horse tractors I've long been a user of Simplicity lawn tractors.  I've noticed that the adjustable tapered roller bearings found in the front wheels of older 1960s and 1970s vintage Simplicity and equivalent Allis-Chalmers tractors are much better than the non-adjustable roller bearings and bushing found in many other tractors including Wheel Horse.
In my garage is a Simplicity 3210V tractor that is being used as a parts source for a 3210V restoration.   I am thinking seriously about swapping the front wheels and bearings on my Wheel Horse C-145.  I believe the spindle diameter on both tractors is 0.750"  so it should work.  The Simplicity bearing setup uses a collar with set screw to set the bearing clearance with is much better than trying to fumble around using shims to adjust wheel endplay.
An additional benefit is that the often lost and overpriced Wheel Horse plastic spindle caps are replaced with steel caps like those used on cars and trucks.  Bearing life will increase because of reduced dirt contamination.
Granted, the Simplicity wheel is slightly different than the Wheel Horse wheel in that it has no grease zerk.  It might be an issue with purists on the show circuit but it makes sense for those of us that use these tractors everyday to strive for decreased maintenance, increased dependability and reduced cost.
Has anyone else done this or thought about doing this?
redrooster
I say go for it. You can't deny better quality!
cleat
Later 520 with the swept axle has the bearings you want. You will need the axle, spindles, and wheels for this conversion then you just need to make your tie rod ends work.
Cleat
  • Similar Content
    • Bach-Ed
      By Bach-Ed
      Trying to restore a Wheelhorse involves a lot of detective work as to what the PO did to the tractor before you got it.  The front rims have pressed in solid flanged bushings.  But on the inner side of one spindle I found this flanged ball bearing.   The parts list shows 4 pieces  #4999 ball bearing.   Should I push out the solid bushing and get new bearings(which is what I suspect should be done)?
      And a related question, shown on the parts list are two washers .015" and .050" thick with a quantity of 3 pieces each.  Since this is an odd number does it mean add the washers as required to take up play?
      Ed
