edwalsh18
First post here! new to red square. new to wheel horse. new to garden tractors... complete rookie here! i purchased a used non running wheel horse yesterday from an ad on craigslist mostly for the implements. i also bought another tractor yesterday, a craftsman gt6000 18hp horizontal shaft. well, i was hanging out with my best friend (google) and i think i figured out my tractor is most likely a 1974 Wheel Horse c120 automatic with a tecumseh hh120. made a quick video and posted on youtube. first time ever posting on youtube so....
oaktown1987
What's the model number they never came with tecumsehs they had a 12 hp kohler
Sent from my iPhone using Tapatalk
daveoman1966
Nice find...  I have one just like and is model # 1-0495.  You should find that model # on a metal tag (about 1" x 3") on the left side of the hoodstand, just about where your left knee would be.  Once you get it going, you'll wonder why you never owned one, then want more of them.
edwalsh18
the info i found was on this site;  http://www.mywheelhorse.com/graphics/file/Wheel_Horse_Products_Master_Model_List.pdf
down on page four under 1974
Edited by edwalsh18
edwalsh18
yeah i just checked to make sure and it is same model #. thanks for reply, do you have any pics of yours?post-12633-0-25824600-1394176036_thumb.j
Edited by edwalsh18
KC9KAS
:WRS:  WOW, the tiller and mid-mount grader are worth the $250!
You made off like a bandit!
Ken B
That is a real nice score! That seat is worth quite a few bucks, its mint! If I were you I'd get that one going and enjoy it. I wouldn't paint it, its way too nice of an original to paint! Give it a good cleaning and it'll look almost new. I seriously doubt it has many hrs. on it going by the overall condition. As far as the Tecumseh being original to the tractor, I don't know if it is or not but it certainly looks as though it has been there since day one. I don't mind the larger hp Tecumseh's, they seem to run pretty good and strong. It probably only needs a carb cleaning. Good luck with it, I wish I came across something like that for 2&a half...
Kelly
You got a great deal, the idler pulleys for the tiller are on the tractor, fix the WH it is a better machine than the sears, and yes the seat is worth about what you paid for the tractor
Kelly
And I just noticed your from California, I bet your the only one on here from there, and one of a few that far west, Welcome
rmaynard
If you check the parts list for the 1-0495, 1974 C-120, it did come with a Lausen (Tecumseh) as an engine choice.
Hodge71
Congrats on your new horse and  :WRS:  I hope you're prepared for the addiction that will follow. You have nothing to fear about the Wheel Horse Automatic tractors. They are very strong runners. Before you get the engine running take some time to ask a few of the guys on here some questions. Tecumsehs are one of the more finicky tractor engines on a Wheel Horse and it may be what the issue is with yours as to why it wont start. I would do a quick oil change in the engine and hit your local Toro dealer and pick up a new hydro filter for the transaxle. If you dont have a Toro dealer local hit up a NAPA auto parts store and buy filter #1410. Its a true hydraulic filter and is made by Wix for Napa. Its as good or even better than OEM. Grab a new 5 qt bottle of the 10w-30 oil of your choice and drain/refill the transmission and replace the filter. From there move to the troubleshooting
1.)Does it turn over and at least crank?
2.)If not, is the battery dead and just need a jump?
3.)If it does crank, does it try to start?
4.)If not, Pull the spark plug and check for spark while you crank. If you have spark while you're cranking reinstall the plug and try and put a small shot of starting fluid or squirt some fuel in the carb and see if it fires. At this point it should do something, as you have air, fuel and spark.
5.)If it doesn't, do a compression check to be sure you have good pressure.
IF you do get it to pop and start or run for a second or 2, run yourself a new fuel line, replace the filter, put some brand new hi octane gas without ethanol if you can get that in Cali. If not, add some Seafoam to it to stabilize your 93 octane and keep things clean.
Dont you worry abut your vid..we love pics and videos!!!
One thing that just popped into my head was make sure you have your parking brake lever up. It disconnects your transmission and takes the load off the engine while starting....Good luck and keep us informed
bowtieguy
Bruce Marion is also from CA....he's the guy that won all the raffle stuff at the 06' big show in PA...huh? Bruce?
tbarnhart
That is a great find!! If you are looking for some more info on the Techys in Wheel Horses, look up the thread "Picking up a C-160 Thursday" by bowtiebutler956. Tecumsehs were only used on the C-series in 74 and 75 and most were 8 speed tractors. Yours with a hydro is a rare tractor. I have a 74 C-160 with a OHV 16 Tecumseh like the one bowtiebutler956 has that I'm trying to freshen up with some paint and decals. The Ignition is the weak point on these engines. Check that first and hope that it is OK. Oem parts are hard to find and expensive, but there are ways to convert it to battery ignition. Any questions, just ask me. Like they said, fix the Horse and sell that Craftsman. =)
AMC RULES
bmsgaffer
If you are wondering why the video makes it look like you are swimming, that is youtube's anti-shake.  :teasing-poke:  It pretty awful at this point, so I would not recommend anyone using it (From personal experience! :banghead: ).
Go to your video, select "enhancements" under the video and then click "revert to original".
Hopefully we will limit the sea-sickness this way. :handgestures-thumbupright:
and sweet tractor! I also vote on resurrecting the wheel horse. Looks like its in great shape!
Edited by bmsgaffer
chazm
WELCOME TO :rs:
Nice :wh:
Ed Kennell
:WRS:
:woohoo:    You are now a felon...What a steal.    I have been using that same tractor with the HH120 Tecky automatic tranny to power a mower and snowblower for the past 15 years. It is the strongest and most reliable working  tractor I own.   I put a new starter ($120) on it when I bought it in 1999, and have not done anything to it since then except normal maintenance. I paid $600 for the tractor, mower deck and push blade .  I picked up a snowblower  at a yard sale for 50 bucks that I have on it now.
If the ignition module is toast, I would look for a 12HP Kohler replacement engine that you can buy for the price of a used module.
Please save this tractor.... They are great little machines.
Edited by ekennell
Bluffhunter
Wow---- What a find !!!  That's going to make you a really nice tractor !!!!
Anyone else notice the dual wheel kit in the brochure at 1:49 ?
Congratulations and enjoy !!!
oaktown1987
I didn't know they ever put tecumsehs on c series
608KEB
Welcome to Red Square. You stole the C-120! When you look the tractor over. You'll see there is no comparison in how well the Wheel Horse is built next to the Sears. I would check the wheel hubs to make sure there tight. Nice find!
leeave96
Nice tractor and implements too!
jackhammer
Ed Walsh18 .. thanks for sharing that story and welcome to this forum.
I would almost bet that your heart is still racing after bringing all that home.
Good luck with your tractor and accessories
608KEB
Wheel-N-It
You got one heck of a good deal, running or not. I have not read the other post due to time but if for some reason the tecky turns out to be a bad engine the replace it with a kohler. make sure its Wheel Horse spec.
The Craftsman is a good one to keep as it has the sleeve hitch on it. A good friend of  mine has one and its been a good garden tractor since day one.
Lane Ranger
Ed  :  You got a great deal and good luck with your new tractors.  Welcome to Red Square the members here can help guide you through any questions or issues you have with your tractor.   The C-120  is a very good model.    The attachments you bought are some of the "prized" finds by Wheel Horse owners!
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $300 Or Best Offer.
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • Charles99
      By Charles99
      ok I'm new to these and first time really working on small engines. i have a k301 engine. i ordered the tune up kit with new coil, condenser, and points. after installed it won't fire. it turns over that's it. I made sure everything is grounded and the points have proper gap . 20. i have voltage at the coil i have spark at the points. i took the plug out that has spark. I'm not sure what else to do I'm about to start putting old parts back on and see if that changes anything. it did run before hand pretty well actually besides an occasion sputter or hiccup.
