mdtoro
520xi starting issue
mdtoro
My 520xi is having trouble starting.  Sometimes when I try to start it I hear the click of the solenoid but it doesn't turn.  Usually trying a few more times and it will turn over and start.
The manual mentions something about servicing the starter.  Does the service consist of cleaning or replacing the brushes?  Brushes look a bit pricey when I looked for them.
Also,  I'm going to replace the battery.  The Interstate workaholic battery has worked quite well!  Hopefully the new ones are just as good!
Edited by mdtoro
doc724
When it finally turns over does it crank slowly or normal speed.  If slowly, it is likely the battery.  If normal speed, then there is an electrical problem somewhere, either in the ignition switch or a relay which powers the starter.  Note a loose connection (12V or ground) wil cause an intermittent problem.  Was it turning over OK when you last ran it?
shallowwatersailor
Just like Don said, look for loose connection, check the fuse block for corrosion (pull each fuse to clean the spade), and safeties before diving into the starter. Depending on the battery's age, it could just be that.
mdtoro
Battery is old so I will replace it.  The terminals were dirty so it might be just the battery.  Will check the other connections while I have it apart.
leeave96
Sounds like the battery.
Jparkes43
Mine did this and it needed a new battery, but I would also check seat switch and other wires as mine had some dodgy connections
Hope this helped
James
Hodge71
I have had a couple horses do this…most recently my '71 Charger 12 auto…everyone of them needed a battery and started just fine after putting a new properly sized battery in
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
