Swemill
D-180 with loader & mods
Swemill
Heres my D-180 from 1975, that i have renovated and build some custom "things" on. For example new gastank, seat, lightning and stainless holders for them, 3-point hitch at front and back, hydraulics with 7 functions and its own pump, new bigger Ross steering box, side exhaust systems with mufflers etc. I have also built tools for it as a snowblade, a loader, counterweight and have also a forklift built going on.
post-9765-0-44498000-1390154758_thumb.jp
post-9765-0-01621400-1390154911_thumb.jp
post-9765-0-46666200-1390155089_thumb.jp
post-9765-0-91499000-1390155111_thumb.jp
redrooster
Excellent! That is a nice set up! You rock! :-)
smoreau
Know that is one nice looking D!! very impressive and I really like the dump trailer!! :handgestures-thumbupright:
chazm
:text-datsphatyo: NICE JOB !!!!   :eusa-clap:
Sparky
You have some great talent there! Beautiful machine.
Mike........
KC9KAS
Very nice looking D and accessories.
Swemill
Thank you very much for your coments! If you're interested i have posted some earlier things in this thread:
Do anybody know if it is possible to tag my old thread with "D-series" ?
rexman72
that is some great work you do.Thanks for sharing.
dodgemike
Very nice work!
Sent from my SCH-S720C using Tapatalk 2
dodgemike
Swemill, did you run a separate
Hydraulic pump? And could you
Share how you drove it?
Thanks. I'm a Mopar guy myself.
But some of my best friends are
Poncho guys. The longer I am on
This forum, the more car guys I
Meet. It would be neat if they gave
Us a separate section where we
Could post our car pics.
Sparky
I added D series to the title but we cant "tag it" now.
Mike............
Swemill
Ok, thanks Mike! I also tried to tag it but didn't succeeded.
Yes DodgeMike, i run a separate pump system but at this moment with a electric motor... It didn't work out well because of the low 15amp alternator that dont feed the battery enough. For some minor work it works for now but i will skip this motor and connect the pump with a shaft to the pto.
wheeledhorseman
Awesome work you've done there! :bow-blue:  :bow-blue:  :bow-blue:
dodgemike
Thanks. I have been tossing the
Idea around of belt driving a pump
Off the motor PTO. It just sits there
All winter anyway.
leeave96
WOW!!!!!
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
      We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
      To start things of I convinced my SO to donate her wheelbarrow to the good cause.
      This is what I started out with:
      Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
      More in next post.
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
