bigbobbyb
Can I swap a K241S with a K341 engine on a C-100?
bigbobbyb
Hello,   I have a 1974 C-100 with a K241S engine in it which is in great shape...but the 10hp engine is junk.  I am looking at buying a 1975 C-160 with a K341 engine in it.  My plan is to replace the engine on the C-100 with the K341.  Will this be a simple swap or are the engines different?
Thanks!
Fordiesel69
Yes, both engines are sold mount with a big base pan.  Should be a very easy swap.  The hard part would be swapping pulleys and the lifting of course.
bigbobbyb
Hi Fordiesel69,
Thanks for your help. Now I will take a look at the donor machine.  Only has about 100 hrs on the 16 hp engine....so would be a great swap.
Bob
oaktown1987
What's wrong with. The 10
Sent from my iPhone using Tapatalk
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
