kicked by a horse
Stuck flywheel :(
kicked by a horse
Alright folks,
I am in need of some serious help. I have a 1978 D-160 with a onan on it.
It had been running all summer with no complaints, a pretty regular worker for moving , tilling, plowing etc.  This winter I fixed up a snowblower I found, put it on, and thought I was all set for winter. After our first snow of the season, I went out to get busy and couldn't get it started. It would reluctantly crank but did not want to turn over.  I did replace the battery and was eventually able to get it started.  I got about six feet out of my shed, engaged the snowblower, and then it died and would not restart.  Since then I have replaced the starter, and in the process noticed the flywheel would not turn. I pulled the plugs and removed the blower belt, and still no movement. In prep for winter I replaced the oil and filter. I just checked the oil level and it was over the full line, but I have not run it more then 15 minutes since changing it.  I also winched the tractor about two lengths (it rolled) to get it back in the shed. I don't recall now if  I disconnected the hydro (so I could make room to get to the starter) before or after I winched it, not sure if it matters.  Any thoughts for what could have happened to cause my previously reliable worker to now be a no go? What are my next steps from here. The motor is still on the tractor, hydro disconnected.
Many thanks for any thoughts you can offer.
TT
I believe I would use a pry bar inserted between two flywheel cooling fins to GENTLY attempt to turn the engine in the OPPOSITE direction of normal rotation. (the engine spins clockwise at the flywheel, so turn it CCW)
Being it's a hydro D series, you might want to disconnect the pump drive shaft and try turning the engine. If the engine turns, the pump is locked up.
If the engine still does not budge using the pry bar method, it might be time to remove it from the tractor and - at the very least - remove the flywheel.
Will await an update.
Desko
I had a onan p216 do the same thing on a generator turned out that the magnets came off the flywheel and jamed into the stator
Edited by Desko
kicked by a horse
Thanks for help.
The hydro shaft is disconnected and it spins freely.  I tried to spin with the fins as hard as I was comfortable doing clock wise and counter clock and it did not budge.
TT
I can't offer much more help beyond the engine & flywheel removal.
Once that's done, you'll have a better idea of what to do next.
Edited to add:
On second though - make sure it's not something in the PTO at the "front" of the engine
I don't know if that's possible, but I would thoroughly check all of the externals first.
Desko
Take the oil filter off your motor is pressure locked and then turn it over
Desko
Oh and don't start it just turn it over by hand to see if will crank or try the old filter and see if it runs
Edited by Desko
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
