mbarb54
Throttle lever / cable sticking 310-8
mbarb54
I have a 310-8 with a Kohler 10-horsepower engine.  It has always started right up in the winter and had no problems every year. This winter it still starts right up, but I've noticed that when the weather is really cold -- under 15 degrees -- the throttle lever doesn't move easily. Once when it was under zero, the lever stuck on high.
I used it this morning to clear snow with temps around 10 degrees and the lever was barely moving.When I finished the lever moved well. I assume it was because the engine helped warm the cable up, My questions are, (1) Do I need a new cable? I hate to go out one day and force it, then have the cable break on me. (2) Is it an easy repair? and (3) Is there any guide anywhere as to how to replace the cable?
Any help would be appreciated.
Thanks,
Michael in Wisconsin
oldlineman
You can work some graphite based lube into the cable and that should help.It will take some time but over time putting lube into the cable jacket it will help. Do not use oil that will get thick in cold weather and make it work harder. I am having the same issue with my 414-8 and have been putting a graphite based lube in and it is helping. Have a great Christmas and safe New year.
sorekiwi
Check out Terry's suggestion in this thread:
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
